Unity Editor on Linux
(Ziba Scott) #1
I know the Unity Linux Editor is a new beast, but I’d love to use it. With the 5.4 and 5.5 releases I get the same error after assigning an fmod project path:
DllNotFoundException: fmod
Near the top fmod.cs where all the platform defines are to route to different dlls, there is no mention of UNITY_EDITOR_LINUX, so it defaults to “fmod”
I played with making it use libfmod or libfmodstudio, but: DllNotFoundException: libfmod.
Am I missing an easy fix? Are there much bigger issues keeping the linux editor from being usable with fmod right now?
(Cameron Baron) #2
Sorry about the delay, it looks like there was a bit more to it than just that. The fix will be out in our next release at the end of the month.
(Ziba Scott) #3
Thanks for the reply. I saw there has been a release since then. Spent a while trying to get it working. No luck. Is it still in the works? Thanks!
(Cameron Baron) #4
Apologies, there was no release at the end of December, the next is end of January which contains the needed libs and integration for Linux.
(Ziba Scott) #5
Sweet. Thanks!
(Ziba Scott) #6
I see you did it! Thanks! It’s working now!
