I’m periodically getting hard crashes from FMOD in Unity that corrupt the game and force me to delete the Library/obj/Temp directories. It takes quite a while to rebuild the project so it’s a big deal.
Here’s the stacktrace from the editor:
FMOD Studio: Creating editor system instance
UnityEngine.StackTraceUtility:ExtractStackTrace () (at /Users/bokken/buildslave/unity/build/Runtime/Export/Scripting/StackTrace.cs:37)
UnityEngine.DebugLogHandler:LogFormat (UnityEngine.LogType,UnityEngine.Object,string,object[])
UnityEngine.Logger:Log (UnityEngine.LogType,object)
UnityEngine.Debug:Log (object)
FMODUnity.EditorUtils:CreateSystem () (at Assets/Plugins/FMOD/src/Editor/EditorUtils.cs:234)
FMODUnity.EditorUtils:get_System () (at Assets/Plugins/FMOD/src/Editor/EditorUtils.cs:311)
FMODUnity.EventManager:UpdateCache () (at Assets/Plugins/FMOD/src/Editor/EventManager.cs:144)
FMODUnity.EventManager:AffirmEventCache () (at Assets/Plugins/FMOD/src/Editor/EventManager.cs:57)
FMODUnity.EventManager:get_Banks () (at Assets/Plugins/FMOD/src/Editor/EventManager.cs:802)
Audio.FMODBankList:ValidateBanks () (at Assets/Audio/FMODBankList.cs:32)
Audio.FMODBankList:OnValidate () (at Assets/Audio/FMODBankList.cs:24)
(Filename: /Users/bokken/buildslave/unity/build/Runtime/Export/Scripting/StackTrace.cs Line: 37)
Start importing Assets/Plugins/FMOD/Cache/Editor/FMODStudioCache.asset using Guid(6e88c41db8b074239b819ea54b77c5d6) Importer(-1,00000000000000000000000000000000)
Done importing asset: 'Assets/Plugins/FMOD/Cache/Editor/FMODStudioCache.asset' (target hash: '7cacb7f05c466b01649da2db2aa7886e') in 0.132647 seconds
Assertion failed on expression: 'IsTransformHierarchyInitialized()'
FMODUnity.EventManager:UpdateCache () (at Assets/Plugins/FMOD/src/Editor/EventManager.cs:317)
[/Users/bokken/buildslave/unity/build/Runtime/Transform/Transform.cpp line 1137]
Obtained 58 stack frames.
#0 0x00000106e9542e in TransformChangeDispatch::QueueTransformChangeIfHasChanged(TransformAccess const&)
#1 0x00000108139c92 in Transform::RebuildTransformHierarchy()
#2 0x00000103d3a462 in AssetHotreload()
#3 0x0000010570aef3 in AssetHotreload(core::hash_set<UnityGUID, core::hash<UnityGUID>, std::__1::equal_to<UnityGUID> > const&)
#4 0x0000010580fad8 in RefreshInternalV2(AssetDatabase::UpdateAssetOptions, ScanFilter const&, InternalRefreshFlagsV2)
#5 0x00000105801d31 in StopAssetImportingV2(AssetDatabase::UpdateAssetOptions, InternalRefreshFlagsV2, ScanFilter const*)
#6 0x000001056c9ebe in AssetDatabase::StopAssetImporting(AssetDatabase::UpdateAssetOptions)
#7 0x0000015e2df839 in (wrapper managed-to-native) UnityEditor.AssetDatabase:StopAssetEditing () {0x7fbdac635d60} + 0x89 (0x15e2df7b0 0x15e2df8e0) [0x14ff24640 - Unity Child Domain]
#8 0x0000015e17763b in FMODUnity.EventManager:AffirmEventCache () {0x7fbdaa4eb588} + 0xfb (0x15e177540 0x15e1776a4) [0x14ff24640 - Unity Child Domain]
#9 0x0000015e17642b in Audio.FMODBankList:OnValidate () {0x7fbf5f5ff400} + 0x1ab (0x15e176280 0x15e176485) [0x14ff24640 - Unity Child Domain]
#10 0x0000014f7cf578 in mono_jit_runtime_invoke
#11 0x0000014f992525 in do_runtime_invoke
#12 0x0000014f992483 in mono_runtime_invoke
#13 0x00000107249ac7 in scripting_method_invoke(ScriptingMethodPtr, ScriptingObjectPtr, ScriptingArguments&, ScriptingExceptionPtr*, bool)
#14 0x0000010724364f in ScriptingInvocation::Invoke(ScriptingExceptionPtr*, bool)
#15 0x000001072433f7 in ScriptingInvocation::InvokeChecked(ScriptingExceptionPtr*)
#16 0x000001072cfc75 in SerializableManagedRef::CallMethod(Object&, ScriptingMethodPtr)
#17 0x000001071fc8bb in MonoBehaviour::CheckConsistency()
#18 0x000001055b34c5 in AwakeFromLoadQueue::InvokePersistentManagerAwake(AwakeFromLoadQueue::Item*, unsigned int, AwakeFromLoadMode)
#19 0x000001055b3316 in AwakeFromLoadQueue::PersistentManagerAwakeFromLoad(int, AwakeFromLoadMode)
#20 0x000001055118cb in PersistentManager::IntegrateAllThreadedObjects()
#21 0x0000010551266c in PersistentManager::LoadAndIntegrateAllPreallocatedObjects(PersistentManager::LockFlags)
#22 0x00000105510f3e in PersistentManager::ReadObject(int, AwakeFromLoadMode)
#23 0x0000010450f2aa in PPtr<EditorExtension>::operator EditorExtension*() const
#24 0x000001050d0a0a in IsPrefabInstanceWithValidParent(Object*)
#25 0x000001050667db in MergeAllPrefabInstancesDuringLoad(AwakeFromLoadQueue*, TransferInstructionFlags)
#26 0x00000106be8b71 in LoadSceneOperation::CompleteAwakeSequence()
#27 0x00000106be84c1 in LoadSceneOperation::CompletePreloadManagerLoadSceneEditor()
#28 0x00000106be7887 in LoadSceneOperation::IntegrateMainThread()
#29 0x00000106be9e6a in PreloadManager::UpdatePreloadingSingleStep(PreloadManager::UpdatePreloadingFlags, int)
#30 0x00000106bea8d1 in PreloadManager::WaitForAllAsyncOperationsToComplete()
#31 0x0000010511f633 in EditorSceneManager::RestoreSceneBackups(std::__1::vector<EditorSceneBackup, stl_allocator<EditorSceneBackup, (MemLabelIdentifier)118, 16> >&, EditorSceneManager::PlayModeChange)
#32 0x00000105129056 in EditorSceneManager::RestoreSceneManagerSetup(SceneManagerSetup const&)
#33 0x00000105129fe7 in EditorSceneManager::LoadSceneManagerSetup(core::basic_string<char, core::StringStorageDefault<char> > const&)
#34 0x0000010488453b in Application::FinishLoadingProject()
#35 0x000001083933e0 in -[EditorApplication applicationDidFinishLaunching:]
#36 0x007fff205870cd in __CFNOTIFICATIONCENTER_IS_CALLING_OUT_TO_AN_OBSERVER__
#37 0x007fff20622b1c in ___CFXRegistrationPost_block_invoke
#38 0x007fff20622a9a in _CFXRegistrationPost
#39 0x007fff2055834e in _CFXNotificationPost
#40 0x007fff212c8bb8 in -[NSNotificationCenter postNotificationName:object:userInfo:]
#41 0x007fff22d9f7d0 in -[NSApplication _postDidFinishNotification]
#42 0x007fff22d9f522 in -[NSApplication _sendFinishLaunchingNotification]
#43 0x007fff22d9c6c1 in -[NSApplication(NSAppleEventHandling) _handleAEOpenEvent:]
#44 0x007fff22d9c317 in -[NSApplication(NSAppleEventHandling) _handleCoreEvent:withReplyEvent:]
#45 0x007fff212f4306 in -[NSAppleEventManager dispatchRawAppleEvent:withRawReply:handlerRefCon:]
#46 0x007fff212f4176 in _NSAppleEventManagerGenericHandler
#47 0x007fff2636f7f3 in _AppleEventsCheckInAppWithBlock
#48 0x007fff2636ef0e in _AppleEventsCheckInAppWithBlock
#49 0x007fff26367c23 in aeProcessAppleEvent
#50 0x007fff287e68a2 in AEProcessAppleEvent
#51 0x007fff22d969a0 in _DPSNextEvent
#52 0x007fff22d94cd5 in -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:]
#53 0x007fff22d87049 in -[NSApplication run]
#54 0x007fff22d5b24c in NSApplicationMain
#55 0x000001083d590f in EditorMain(int, char const**)
#56 0x000001083d5c19 in main
#57 0x007fff204b3f3d in start
Launching bug reporter
QObject: Cannot create children for a parent that is in a different thread.
(Parent is QObject(0x7fcdcc771530), parent's thread is QThread(0x7fcdcc607030), current thread is Thread(0x7fcd6d50a400)
And this is what’s in FMODBankList for reference:
using UnityEngine;
using System;
#if UNITY_EDITOR
using FMODUnity;
using UnityEditor.SceneManagement;
using UnityEditor.Experimental.SceneManagement;
#endif
namespace Audio
public abstract class FMODBankList : MonoBehaviour
// References
public string SceneName;
public List<SoundInspectorBank> banks;
#if UNITY_EDITOR
void OnValidate()
if (PrefabStageUtility.GetCurrentPrefabStage() != null) return;
SceneName = EditorSceneManager.GetActiveScene().name;
ValidateBanks();
private void ValidateBanks()
// Get All Banks
HashSet<SoundInspectorBank> allBanks = new HashSet<SoundInspectorBank>();
HashSet<SoundInspectorBank> combinedBanks = new HashSet<SoundInspectorBank>();
foreach (EditorBankRef bank in EventManager.Banks) allBanks.Add(SoundInspectorBank.Create(bank.Name));
// Sanitize Current Banks
if (banks != null)
foreach (SoundInspectorBank bank in banks)
bank.Sanitize();
if (String.IsNullOrEmpty(bank.bankPath) || allBanks.Contains(bank))
if (combinedBanks.Contains(bank)) bank.Reset();
combinedBanks.Add(bank);
// Add Any Missing Banks
// Banks for Scene
if (bank.Name.StartsWith(SceneName))
combinedBanks.Add(SoundInspectorBank.Create(bank.Name));
// Update Bank List
banks.Clear();
banks.AddRange(combinedBanks);
#endif
Can someone help me figure this out? It’s brought development to a halt. It seems like accessing EventManager.Banks from OnValidate() is causing problems. How can I fix that?
Does there need to be a new function in EventManager:
public static bool IsEventCacheReady { get => eventCache != null; }
to check in OnValidate():
void OnValidate()
if (!EventManager.IsEventCacheReady) return;
Any guidance would be greatly appreciated!
