Unnecessary Square Root
Doing some performance improvements for our game (Unity).
I’ve noticed that in RuntimeManager.cs within UpdateActiveEmitter you are doing a potential unnecessary square root.
Is there a reason for this?
I’ve made a potential fix, could you look into this.
Previous code
public static void UpdateActiveEmitter(StudioEventEmitter emitter, bool force = false)
            // If at least once listener is within the max distance, ensure an event instance is playing
            bool playInstance = false;
            for (int i = 0; i < Listeners.Count; i++)
                if (Vector3.Distance(emitter.transform.position, Listeners[i].transform.position) <= emitter.MaxDistance)
                    playInstance = true;
                    break;
            if (force || playInstance != emitter.IsPlaying())
                if (playInstance)
                    emitter.PlayInstance();
                else
                    emitter.StopInstance();
Amended code
                // Maybe cache this?
                float maxDistanceSqr = emitter.MaxDistance;
                maxDistanceSqr *= maxDistanceSqr;
                if ((emitter.transform.position -Listeners[i].transform.position).sqrMagnitude <= maxDistanceSqr)
                    break;
                if (playInstance)
                else
Thanks,
Tom
Thank you for the suggestion!
What version of the integration are you using?
2.01.09
Thank you,
I have passed it onto our development team to look into further, we appreciate the suggestion!
