Hi all,
I’m trying to use the dsp plugin examples in the low level api with the dsp_custom example.
I seem to be able to load the plugins fine with
result = system->loadPlugin(“fmod_distance_filter.dll”, 0, 0);
ERRCHECK(result);
but any further attempt to interact with it such as through
result = system->createDSPByPlugin(0, &dllDsp);
ERRCHECK(result);
ends up getting the following error:
FMOD error 54 - A requested output, dsp unit type or codec was not available.
Am I simply loading the plugin incorrectly? I’ve been following the instructions found in; https://www.fmod.com/resources/documentation-api?version=1.10&page=content/generated/overview/plugin_api_dsp.html
Thanks in advance!
