Using EventInstance captured from START_EVENT_COMMAND callback
I am trying to get an event instance from a START_EVENT_COMMAND callback and then use it later on in managed code to update params/attach it to a transform.
The callback seems to work without complaint, but I’m getting an assert when trying to get the description of this event instance later on:
[FMOD] assert : assertion: 'inst->mHandleBits != 0' failed
Here is how my callback looks:
[AOT.MonoPInvokeCallback(typeof(EVENT_CALLBACK))]
		static RESULT HandleCallback(EVENT_CALLBACK_TYPE type, IntPtr instancePtr, IntPtr parameterPtr)
			FMOD.Studio.EventInstance instance = new FMOD.Studio.EventInstance(instancePtr);
            IntPtr callbackInfoPtr;
            FMOD.RESULT result = instance.getUserData(out callbackInfoPtr);
            if (result != FMOD.RESULT.OK)
                UnityEngine.Debug.LogError("FMOD Callback error: " + result);
                return result;
            else if(callbackInfoPtr != IntPtr.Zero)
                GCHandle callbackHandle = GCHandle.FromIntPtr(callbackInfoPtr);
                StartEventData callbackInfo = (StartEventData)callbackHandle.Target;
                switch (type)
                    case FMOD.Studio.EVENT_CALLBACK_TYPE.START_EVENT_COMMAND:
                            if(parameterPtr != IntPtr.Zero)
                                try
                                    FMOD.Studio.EventInstance param = new FMOD.Studio.EventInstance(parameterPtr);
                                    if(param.isValid() && param.hasHandle())
                                        callbackInfo.Triggered = 1;
                                        callbackInfo.StartedInstance = new EventInstance(parameterPtr);
                                catch(Exception e)
                                    UnityEngine.Debug.Log(e);
                        break;
                    default:
                        break;
            return FMOD.RESULT.OK;
And here is the call where I get the assert (this happens later down the line in a monobehaviour update where I wait for the “Triggered” to be set to 1):
ignitionCallback.Data.StartedInstance.getDescription(out var desc);
What am I doing wrong? Or is there a different way I should go about updating an instance that was started this way?
If needed I can provide more code than this.
Also, interestingly, using the runtime manager to attach this instance to a gameobject does not produce any errors.
Thank you.
I think I might need a little more context to figure out what’s going on here- can you please share a code snippet for what’s happening when you call setCallback?
Sure,
the callback is wrapped in a class and set when that class is constructed, like so:
		public FMODStartEventCallback(EventInstance eventInstance)
            data = new StartEventData();
            callbackHandle = GCHandle.Alloc(data, GCHandleType.Pinned);
			actualCallback = new FMOD.Studio.EVENT_CALLBACK(HandleCallback);
			eventInstance.setUserData(GCHandle.ToIntPtr(callbackHandle));
            eventInstance.setCallback(actualCallback, EVENT_CALLBACK_TYPE.START_EVENT_COMMAND);
Another class then later asks this wrapper class for the data from the callback, which is defined like this:
    [StructLayout(LayoutKind.Sequential)]
    public class StartEventData
		public EventInstance StartedInstance;
        public int Triggered;
the returned EventInstance also returns true on isValid and hasHandle, but trying to get the description fails as mentioned above.
Thanks for the extra info- it seems there is a problem with the underlying API and the START_EVENT_COMMAND callback isn’t returning a valid handle to the new EventInstance, even though isValid and hasHandle are both somehow returning true.
I’ve written up a bug report for the dev team to look into.
Thanks for looking into it!
We’ll try to work around the issue for now.
