When panning, why is there still a small sound out of the opposite side?
I’d like to play my sounds entirely on the left or right channel without effect on the other.
I’m happy to accomplish this in either code or through the studio.
Are you using the stereo pan control? Just looking at metering here there is no leak on either side.
If you’re using the surround panner there’s things like stereo width you need to reduce to 0 and things like that.
It turns out cheap headphone extension cables will bleed signal from one channel to the other.
