Why i can hear my sound every where in the level and only in one channel ?
hi , im having trouble with the fade out of the sound, i can still hear the sound in every part of the map, i.ve check the circles around the little speaker and they are small and i only can hear it in one channel (left channel).
some one can help me please ?
We need more information before we can diagnose this issue. What are the “Min & Max Distance” values of the 3D Panner effect in the event that you’re having trouble with? What “Distance Attenuation” is that 3D Panner set to use? How many units wide is your map? How are you positioning the listener, the camera, and the emitter? If you edit this information into your question, we may be able to help.
