MD5 hash of fmod_WSA82_X64.dll:
9e5cd3fda087c7892366ad25a6ea0a33
Its older than 2016/02/12 (YYYY-MM-DD)
We’d need to know the version number, we don’t have a lookup based on hash.
i got an agent to look through dlls but its a little bit confusing. basically every single release through 1.06.00 to 1.08.00 should be it. i dont get why i can access 1.07.1 and then straight to 1.08.00. also, will it be enable djust for UWP or for all platforms?
We don’t host every version of FMOD due to size, you’ll see occasional single versions due to a particular user request.
If you’re a developer, try looking at yourfmod_common.hthere is a version number near the top.
If you’re a user you would need to contact the developer of the game/software that’s using FMOD for the particular version they used.
