Hi Folks,
I’ve tried loading various IRs, mono and stereo, all at my project’s settings (16-bit/48k), but I’m not getting any wet output. I’ve tried via send to a return and within an event. The dry output works.
I also have 2.01.09 installed and the effect works as expected there.
Any thoughts?
Thanks, Matt
Unfortunately, I cannot reproduce the issue using 2.02.19 on Windows.
What operating system are you on? Does it work on any other 2.02.XX versions?
Would it be possible to get the IRs that you have been testing? These can be uploaded to your profile, please note you’ll have to register a project with us to upload files.
Hi Connor,
Thanks for the quick reply. I’ve uploaded 4 IRs for testing. I will download a newer 2.02 version of the editor to test, as well.
FIXED!!!
It turns out that I had set a really low (96 samples) dsp buffer in the editor, which prevented the plugin from working. I have it set to 512 and the plugin is working as expected
Thanks, Matt
Good to hear it is working and thank you for sharing the solution.
