Hi all,
First-off, this is related to the Core API, than the Studio API.
I’m working on a 2D, side-view game and recently put 3D sound into place for sound panning when effects happen to the left or right of the player. It works wonderfully, but I’ve run into an unfortunate difficulty. The game can have wrapping maps, i.e. the map goes from 0 - n, and when you pass n (when going in the positive direction), your position loops back around to ~0.
Unfortunately, this presents a challenge with 3D sound because, as far as I know, I can’t specify the calculation used to determine the distance (and direction) between the listener and a given sound (if I could this would be straightforward to solve).
I’ve tried searching for this and looked through the docs but had no luck, and I’d like to know if anyone’s had to deal with this issue, or if anyone has suggestions that could help.
For what it’s worth, I’ve come up with 2 possible solutions, but I can’t say I love either of them:
Play a copy of every sound at
soundPosition + (soundPosition > mapWidth/2 ? mapWidth : -mapWidth)and rely on attenuation to quiet the sound appropriately. That way the sound will always be playing in the more appropriate direction, e.g. if the map width is 2000 and the listener is at 1800, a sound played at 200 will also play at 2200, which will be 400 away to the right, which is correct.
The downside here is that copies of each sound get created and, if the map wraps in X and Y (which can theoretically happen though it’d be rare), this can mean 4 copies for each sound. -
Change any playing sound’s positions according to the listener’s position. Whenever the listener moves more than half of the map away from a sound, that sound would be shifted to its reverse position. So, given the example above, while the listener is < 1200 the sound would stay where it is, but once they go past 1200, the sound would move to 2200, so it’d play on the right side.
The first downside here is the extra iteration over every sound every frame, though that could be optimized to not be a big problem. The second downside is that the game can be played in 2, 3 or 4-player splitscreen, so this process would have to be done for up to 4 players, since any of those 4 players could be close enough to trigger a position shift in a given sound.
Also, this is fairly unrelated, but while I’m asking questions I want to confirm that I’m correct in my understanding; using ChannelControl::set3DLevel(<1) to lessen the sound panning strength removes automatic distance attenuation right?
Thanks for your time,
Gacyr
