Is there a way to access the UE4 level geometry information - meaning the environment obstacles, etc in an FMOD Studio plugin in addition to the location and velocities of the source and listener?
Thanks,
Udit
Thanks,
Udit
Right now geometry API is a low level only feature, the FMOD Studio events will most likely be working with it in the 1.09 release.
As far as a plugin goes, it doesn’t really get that sort of information via the plugin API, you’d have to set up some code to set the parameters for the DSP.
