So basically whenever there’s alot of sound effects the game’s audio starts stuttering and just not playing some. All of this only happens in the built version, the Editor is completely fine. I’ve already tried increasing the max voices all the way and still no luck. Some help would be very much appreciated right now.
Can I get some additional info from you? Specifically:
- Your FMOD Studio and FMOD for Unity versions
- Your Unity version
- A log from a development build in which you reproduce the issue, with your Logging Level set to Log and API Error Logging enabled
- A profiler session recorded in Studio via Live Update in which you reproduce the issue, packaged and exported
You can upload the log and profiler session to the uploads tab of your FMOD user profile.
