Bank file is Assets folder failed to load (not found)
Hi, I am using FMOD Studio to build a project in Unity.
-Fmod 2.02.21
-Unity 2023.2.16
In order to share the Unity project I put the built bank files in a folder like this :
-Assets/Game/Sound/Master.bank
-Assets/Game/Sound/Master.strings.bank
I set up this folder into FMOD Settings and it looks ok:
-Source Type: Single platform build
-Path: Assets/Game/Sound
  • The Inspector finds the files and shows all info and options properly.
The problem is when playing the game. I get a console error :
[FMOD] RuntimeBankModel::openFile : Failed to open file ‘Assets/Game/Sound/Desktop/Master.strings.bank’
(No sound is played)
Why is it adding ‘/Desktop’ to the path?
If I put the files into ‘Assets/Game/Sound/Desktop’, then the error is :
[FMOD] RuntimeBankModel::openFile : Failed to open file ‘Assets/Game/Sound/Desktop/Desktop/Master.strings.bank’
I found that I can keep the files into ‘Assets/Game/Sound/Desktop’ and put only ‘Assets/Game/Sound’ in the path to the Fmod Settings and the game plays fine (with sound), but the Inspector keeps giving an error message :
“Build path ‘Assets/Game/Sound’ does not contain any built banks.” (and no info or options are shown)
Maybe there is a setting somewhere to prevent the system to add ‘Desktop’ to the path?
Thanks !
What operating system are you working on? Could you try deleting your "D:\UnityProjects\MyProject\Assets\Plugins\FMOD\Resources\FMODStudioSettings.asset". This will refresh your FMOD Settings. I was only able to reproduce the issue once.
Hope this helps.
My OS is Windows 11.
I deleted FMODStudioSettings file and went through the setup wizard and it’s working now.
I also deleted the ‘Cache’ folder content.
I’m not sure, but I think that if someone else is sharing the project, he will have to delete his Cache folder too. Is it right? (It seems happened to me)
Thanks for your help!
If you have a look at our Unity source control example here Unity Integration | Using Source Control - git ignore example, the cache files should be ignored as they are updated locally. I suggest updating your git ignore if you are not ignoring these files.
Hope this helps.
