Hello! I’m just trying to link my FMOD banks to my Unity project, using the latest version of FMOD and the Unity integration. I did recently update the Unity integration to this version if relevant.
When I try Single Platform, I navigate to Assets/FMOD/ and select, and the sound works, but the editor (FMOD settings in Unity) says that the location does not contain any built banks (and I can’t edit the settings). If I try selecting the Desktop folder, the editor shows up, but FMOD throws an error on startup, saying it can’t find anything under Assets/FMOD/Desktop/Desktop/. The same happens with both other selection methods as well. It seems to me that Unity is appending a /Desktop/ to the build path.
Now, the weirder part is on GitHub. I left it on Single Platform and Assets/FMOD, so that the audio worked (even though the banks were under /Desktop/). As soon as someone else opens the project, they get an error that the path is wrong - It’s looking for banks under Assets/FMOD/, the actual path I specified. I’ve tried rebuilding, redownloading the repo, messing with lots of settings, all to no avail. Any help?
Just to confirm, what version of Unity and FMOD are you using?
Can you please try doing the following:
- Set Source Type to “Single Platform Build”
- Set Build Path to “Assets/FMOD/Desktop”
- In file explorer, go to “Assets/Plugins/FMOD” and delete the “Cache” directory
- In the Unity menu, click through to FMOD>Refresh Banks
That worked, thank you!!
Edit: and I’m on Unity 2020.3.17f1 and FMOD 2.02.3.
I’m having this exact same issue. I’ve followed the steps suggested but it hasn’t worked. The Cache folder gets recreated almost instantly when I delete it.
The error says it can’t find master.bank in Assets/FMODAssets/Desktop/Desktop. If I create another folder within Desktop also called Desktop, the error says it can’t find master.bank in Assets/FMODAssets/Desktop!
I’m using Unity 2021.2.8f1 and FMOD 2.02.04
Can you please share a screenshot of your FMOD Unity settings?
I’m new to FMod, just installed it and watching videos to figure out how to use it. but I’m having this same, i tried the fix mentioned above but it didn’t fix anything. It is still adding an extra desktop to the path, I even tried creating another folder named desktop and put the original one with the bank inside it to see if it would work. but it didn’t it just kept adding another one (Example it said: /Desktop/Desktop/Desktop).
I’m using Unity Version 2021.1.9 and FMod version 2.02.19.
here are pictures to show you my settings for FMod
I have not been able to reproduce this issue. Can you please share your full Build Path?
Can you also please try switching the Source Type to “Multiple Platform” and let me know if you get any errors?
