Hello!
I’ve found an issue in the latest (FMOD 2.02.17) where the instrument clicks whenever you alter its pitch and the audio source beginning isn’t zero-cross, even if the end ends with a fade-out.
The only way I can avoid clicking is if I apply a micro fade-in, as I’m supposing FMOD is somehow jumping back to the sample’s beginning when it’s over.
