Hello, i have an issue to report. I am using Fmod 2.01.05 Win 64 bit, Unreal Engine 4.25.3, Fmod plugin 2.01.05. Fmod build is in Vorbis 37% Surround 5.1
I recently noticied that audio files recorded with profiler sessions have some clicks all the time. I uploaded an example audio file and also some screenshots with maximum values at that time. None of the values are extreamly high so i have no clue what is causing this. In this segment you can hear a bit of ambiance and some footsteps, no loud sounds.
Thank you
PS: I see that the values are a bit small to read, CPUMixer 10,52%, CPUupdate Total 4,11%, Memory 677,369 KB, Levels Peak -27 RMS -33, Voices 15. Instances All Total Playing Active 20
Cheers
