I want to use a Pitch Shifter which is going to be controlled by a parameter. However, I don’t want the pitch shifter to be always running. Is there a way to avoid having it always turned on?
I checked some threads from a couple years ago and it was said that a solution is planned.
Did something happen in the meantime?
The best solution in my opinion would be the ability to automate the bypass of an effect (like you can do in any DAW). Second best solution would be a dry/wet knob that you can automate.
Unfortunately not. It may be possible to use the Core API to use setBypass() on the channelgroup of the bus it resides on, but this is quite complicated and untested so may not work entirely.
