Can I access LowLevel system by Unity Integration?
I am trying to play procedual midi file via unity integration on iOS,but it seems that low-level system was not wrapped by these C# code.
So is it possible to access Low-level System via C# code? Or I must create native Obj-C code?
PS:Can I create midi-events insdead creating midi file to play sounds in .dls file?
Thanks,
artascope
Hi Artascope,
We have exposed the complete low-level API in the latest release. You can retrieve the low-level system from the Studio system object, and the API is in fmod.cs.
No you cannot fire midi events directly, you must play a midi file.
