I have REV .model files and I’d like to know if I can import them into fmod, and if so how?
REV is advertised as compatible with FMOD but if you have your rev sweep we can recommend AudioGaming which has the same technology to process your sound into a realtime parameterized engine model. The eval plugin is available in FMOD Studio but you will need to contact AudioGaming for the evaluation of the tool.
See https://www.fmod.com/partners
