Is it possible to set a parameter value in a quantized way? For instance, I’d only like to fade in the volume of an instrument in a song after a bar has completed. Is that possible?
With a command instrument with trigger behavior quantization settings (set to 1 bar). Is that what you’re looking for?
That’s perfect! Thanks!
