Parameter changes quantized
FMOD 2.02.06
Hey everyone,
I was wondering it is possible to have a parameter changed being quantized while being changed over a script; ie, you would changed a parameters but the changed would only have effect at the beginning of a bar or something like that.
Thank you for the advice!
At the time of writing (August of 2022) there is no way to quantize a change in parameter value.
That being said, it is possible to quantize the triggering of instruments and most logic markers. This means that while it is not possible to quantize a change in parameter value, it is possible to quantize most things that would be affected by a change in parameter value. Only automation cannot be quantized in this fashion.
The thing is that what I’d like to quantize is a volume change of the track, for layering control. Using quantization to trigger the instruments has not work for me in this project, so I’m looking for options.
As I said, we do not currently support quantizing changes in parameter value.
That being said, you could work around this limitation by using command instruments. A set parameter command instrument can set the value of a parameter, and can be quantized to only trigger on the beat; as such, if you created two parameters, one that is set by your game’s code and triggers one or more command instruments, and one that is set only by the command insturments and is used to automate your track volume, you could achieve the behavior you want for specific discrete volume levels. If you need to be able to set the volume to arbitrary levels, that could be done by using just one set parameter command instrument if you automate its value property, but you would need to ensure the command instrument is retriggered regularly (perhaps by an additional parameter subject to LFO modulation.)
Have any of the new updates made this process any easier?
As of the time of writing (July of 2025) we do not support quantizing changes in parameter value, and there have been no changes that would simplify the workflow involved in the workaround I described in my previous post.
@vincentoliver here the fix was not to rely on fmod for that part, as in quantized volume change. i found a different work around.
for my purpose, i ended up creating a way to layout music and the ‘quantized change’ was not in volume but of layer. that worked out for my purposes.
let me know if you need more info or what’s your specific context and i can try to unearth that project and/or give you some tips.
Thanks @shplss, I don’t remember exactly why I wanted to do this. Perhaps to A/B mix between layers (which I want to do all the time). Would be great to see your workaround. Thanks!
