Connect FMOD to Unity Game Error
(Alberto Carlassare) #1
‪#‎liveupdate‬ ‪#‎unity‬
Hi! I can’t get FMOD (1.07) synced to my Unity (5.2.2.1f) Game.
I do the following:
  1. I add ‪#‎define‬ LIVE_UPDATE at the beginning of FMOD_StudioSystem script
  2. In FMOD: I save the project, build banks and export GUIDS
  3. In Unity: I Import the banks (or Refresh Event List). Save the project and Save Scene. Play the game (the scene is empty).
4 In FMOD: File/Connect to game - IP Address: localhost - Push Connect
FMOD give me back this message:
"Studio was unable connect to “localhost” as a connection error occurred: “Socket Error”
Please check that the IP address is correct, the game is running and live update is enabled"
WHY?? How can I get it working?
(mightypants) #2
Check out this post:
http://www.fmod.org/questions/question/fmod-studio-integration-liveupdate-cannot-connect-with-unity-5-beta/
(Alberto Carlassare) #3
I’ve seen it, but I don’t have no FMOD_StudioSystem.cpp script after importing fmodstudio10701.unitypackage into unity. There is a FMOD_StudioSystem.cs . Is that the same?
The post you suggested me speak about line 258. My line 258 of FMOD_StudioSystem.cs has the following code:
(first line 257)
DontDestroyOnLoad(gameObject);
[this is my line n258]
FMOD.Studio.UnityUtil.Log(“FMOD_StudioSystem: System_Create”);
ERRCHECK(FMOD.Studio.System.create(out system));
    FMOD.Studio.INITFLAGS flags = FMOD.Studio.INITFLAGS.NORMAL;
	FMOD.System sys;
	ERRCHECK(system.getLowLevelSystem(out sys));
	FMOD.ADVANCEDSETTINGS advancedSettings = new FMOD.ADVANCEDSETTINGS();
	advancedSettings.randomSeed = (uint) DateTime.Now.Ticks;
(end of code)
If I put there that code console give ma back an error. What to do? Is there the script already modified?
(Nicholas Wilcox) #4
The correct define is FMOD_LIVEUPDATE
Read the documentation here: http://www.fmod.org/documentation/#content/generated/engine_unity/configuration.html
(Alberto Carlassare) #5
Thanks Nicholas,
that was the issue. just adding #define FMOD_LIVEUPDATE in FMOD_StudioSystem.cs script FMOD Connect straight at localhost:9265
Such a simple mistake!
