Console SDK availability between releases
Hello !
We’re maintaining a custom Unity integration of FMOD for multiple Unity projects on a wide range of platforms (including console). For this, we retrieve the native libraries from the official Unity integration packages.
The issue we’re facing when upgrading between two minor releases is that the console SDK that are available can vary. For instance, at the moment, version 2.03.09 has PS5 SDK 9 and 11 but not 10 (which is available for version 2.03.08). On Switch, SDK 19.x was available for version 2.03.07 but not since.
Would it be at all possible to make those more consistently available between releases. I’m not expecting packages for every versions of every SDK that exist, of course, but it would be nice if there were at least one version for every major SDK version (unless no longer supported), in order to have a clearer upgrade path.
Thanks in advance for any answer you may have on this issue.
We can build different versions on request. Just ask us for the ones you need.
