Hello!
I am trying to control the minimum and maximum distance of a spatializer effect through two parameters called MinDistance and MaxDistance respectively.
However, after setting up the automation I have noticed there is a discrepancy between the value of the parameter, and the value being controlled on the effect.
This is the setup on the effect, each parameter is completely linear to what it is controlling, and both have a range from 0 to 10000
and here is the preview values of the parameters
While the values do change as I move my parameters around, it appears to be off slightly,
MinDistance is set to 1.25k, but the minimum distance on the effect reads 2.83, it is the same with the MaxDistance parameter. Changing the parameters does indeed modulate my effect, but seemingly at the in correct value, despite having the automation completely linear like so:
Any help on this would be greatly appreciated
