SystemI::createSoundInternal : Sample 0/1: name='KnifeThrowerAttack3_Var2', format=2, channels=2, frequency=48000, lengthbytes=4352, lengthpcm=22255, pcmblocksize=0, loopstart=0, loopend=0, mode=0x00000000, channelmask=0x00000000, channelorder=0, peakvolume=0.074860.
SystemI::createSoundInternal : Create name='', mode=0x02000202
SystemI::createSoundInternal : exinfo->cbsize = 144
SystemI::createSoundInternal : exinfo->length = 9793376
SystemI::createSoundInternal : exinfo->fileoffset = 382592
SystemI::createSoundInternal : exinfo->numsubsounds = 1
SystemI::createSoundInternal : exinfo->inclusionlist = 0xb7de7d14
SystemI::createSoundInternal : exinfo->inclusionlistnum = 1
SystemI::createSoundInternal : exinfo->suggestedsoundtype = 5
SystemI::createSoundInternal : exinfo->useropen = 0xa7193075
SystemI::createSoundInternal : exinfo->userclose = 0xa7193105
SystemI::createSoundInternal : exinfo->userread = 0xa719311d
SystemI::createSoundInternal : exinfo->userseek = 0xa7193199
SystemI::createSoundInternal : exinfo->fileuserdata = 0xaa5c63c8
SystemI::createSoundInternal : exinfo->initialseekpostype = 1
SystemI::DSPCodecPoolRegister : register codec pool for pool type 5
SystemI::createSoundInternal : Sample 0/1: name='KnifeThrowerAttack2_Var2', format=2, channels=2, frequency=48000, lengthbytes=3072, lengthpcm=15437, pcmblocksize=0, loopstart=0, loopend=0, mode=0x00000000, channelmask=0x00000000, channelorder=0, peakvolume=0.067078.
06-02 13:37:23.956 1790-2131/? I/fmod: SystemI::createSoundInternal : exinfo->useropen = 0xa7193075
SystemI::createSoundInternal : Sample 0/1: name='KnifeThrowerAttack2_Var4', format=2, channels=2, frequency=48000, lengthbytes=3040, lengthpcm=15455, pcmblocksize=0, loopstart=0, loopend=0, mode=0x00000000, channelmask=0x00000000, channelorder=0, peakvolume=0.072815.
06-02 13:37:23.957 1790-2131/? I/fmod: SystemI::createSoundInternal : Create name='', mode=0x02000202
SystemI::createSoundInternal : Sample 0/1: name='KnifeThrowerAttack3_Var1', format=2, channels=2, frequency=48000, lengthbytes=4736, lengthpcm=22908, pcmblocksize=0, loopstart=0, loopend=0, mode=0x00000000, channelmask=0x00000000, channelorder=0, peakvolume=0.070129.
06-02 13:37:24.009 29391-19087/? W/NightController: handleMessage() - Camera is empty, set night mode later
06-02 13:37:24.091 1790-2129/? E/fmod: assert : assertion: 'mPlaybackSystem->destroyEventInstance(this) == FMOD_OK' failed
06-02 13:37:24.131 1790-2129/? A/libc: Pure virtual function called. Are you calling virtual methods from a destructor?
06-02 13:37:24.141 29391-19087/? W/NightController: handleMessage() - Camera is empty, set night mode later
06-02 13:37:24.249 29391-19087/? W/NightController: handleMessage() - Camera is empty, set night mode later
06-02 13:37:24.271 1790-2126/? W/fmod: OutputRingBuffer::read : Buffer starvation detected, requested 2048 bytes, 1024 / 16384 bytes available.
OutputRingBuffer::read : Increasing block count to 9.
06-02 13:37:24.272 1790-2126/? W/fmod: OutputRingBuffer::read : Buffer starvation detected, requested 5632 bytes, 0 / 16384 bytes available.
OutputRingBuffer::read : Increasing block count to 10.
06-02 13:37:24.290 1790-2126/? W/fmod: OutputRingBuffer::read : Buffer starvation detected, requested 7680 bytes, 0 / 16384 bytes available.
OutputRingBuffer::read : Increasing block count to 11.
06-02 13:37:24.364 29391-19087/? W/NightController: handleMessage() - Camera is empty, set night mode later
06-02 13:37:24.616 29391-19087/? I/chatty: uid=10029(com.oneplus.camera) Camera Thread identical 2 lines
06-02 13:37:24.739 29391-19087/? W/NightController: handleMessage() - Camera is empty, set night mode later
06-02 13:37:24.769 837-908/? D/audio_hw_primary: out_set_parameters: enter: usecase(1: low-latency-playback) kvpairs: suspend_playback=true
06-02 13:37:24.769 837-908/? D/audio_hw_extn: audio_extn_fm_set_parameters: Enter
06-02 13:37:24.769 837-908/? D/audio_hw_hfp: hfp_set_parameters: enter
06-02 13:37:24.786 837-908/? D/audio_hw_primary: out_set_parameters: enter: usecase(1: low-latency-playback) kvpairs: suspend_playback=false
06-02 13:37:24.787 837-908/? D/audio_hw_extn: audio_extn_fm_set_parameters: Enter
06-02 13:37:24.787 837-908/? D/audio_hw_hfp: hfp_set_parameters: enter
06-02 13:37:24.791 837-908/? D/audio_hw_primary: out_set_parameters: enter: usecase(1: low-latency-playback) kvpairs: suspend_playback=true
06-02 13:37:24.792 837-908/? D/audio_hw_extn: audio_extn_fm_set_parameters: Enter
06-02 13:37:24.792 837-908/? D/audio_hw_hfp: hfp_set_parameters: enter
06-02 13:37:24.807 837-908/? D/audio_hw_primary: out_set_parameters: enter: usecase(1: low-latency-playback) kvpairs: suspend_playback=false
06-02 13:37:24.807 837-908/? D/audio_hw_extn: audio_extn_fm_set_parameters: Enter
06-02 13:37:24.807 837-908/? D/audio_hw_hfp: hfp_set_parameters: enter
06-02 13:37:24.814 837-908/? D/audio_hw_primary: out_set_parameters: enter: usecase(1: low-latency-playback) kvpairs: suspend_playback=true
06-02 13:37:24.815 837-908/? D/audio_hw_extn: audio_extn_fm_set_parameters: Enter
06-02 13:37:24.815 837-908/? D/audio_hw_hfp: hfp_set_parameters: enter
06-02 13:37:24.829 837-908/? D/audio_hw_primary: out_set_parameters: enter: usecase(1: low-latency-playback) kvpairs: suspend_playback=false
06-02 13:37:24.830 837-908/? D/audio_hw_extn: audio_extn_fm_set_parameters: Enter
06-02 13:37:24.830 837-908/? D/audio_hw_hfp: hfp_set_parameters: enter
06-02 13:37:24.834 837-908/? D/audio_hw_primary: out_set_parameters: enter: usecase(1: low-latency-playback) kvpairs: suspend_playback=true
06-02 13:37:24.834 837-908/? D/audio_hw_extn: audio_extn_fm_set_parameters: Enter
06-02 13:37:24.834 837-908/? D/audio_hw_hfp: hfp_set_parameters: enter
06-02 13:37:24.846 29391-19087/? W/NightController: handleMessage() - Camera is empty, set night mode later
06-02 13:37:24.849 837-908/? D/audio_hw_primary: out_set_parameters: enter: usecase(1: low-latency-playback) kvpairs: suspend_playback=false
06-02 13:37:24.849 837-908/? D/audio_hw_extn: audio_extn_fm_set_parameters: Enter
06-02 13:37:24.849 837-908/? D/audio_hw_hfp: hfp_set_parameters: enter
06-02 13:37:24.851 4878-4878/? E/chromium: [0602/133724.850334:ERROR:elf_dynamic_array_reader.h(61)] tag not found
06-02 13:37:24.855 837-908/? D/audio_hw_primary: out_set_parameters: enter: usecase(1: low-latency-playback) kvpairs: suspend_playback=true
06-02 13:37:24.855 837-908/? D/audio_hw_extn: audio_extn_fm_set_parameters: Enter
06-02 13:37:24.855 837-908/? D/audio_hw_hfp: hfp_set_parameters: enter
06-02 13:37:24.860 1790-2126/? W/fmod: OutputRingBuffer::read : Buffer starvation detected, requested 7680 bytes, 3072 / 16384 bytes available.
OutputRingBuffer::read : Increasing block count to 12.
06-02 13:37:24.870 837-908/? D/audio_hw_primary: out_set_parameters: enter: usecase(1: low-latency-playback) kvpairs: suspend_playback=false
06-02 13:37:24.870 837-908/? D/audio_hw_extn: audio_extn_fm_set_parameters: Enter
06-02 13:37:24.870 837-908/? D/audio_hw_hfp: hfp_set_parameters: enter
06-02 13:37:24.884 1790-2129/? E/CRASH: signal 6 (SIGABRT), code -6 (?), fault addr --------
Build type 'Release', Scripting Backend 'il2cpp', CPU 'armeabi-v7a'
Build fingerprint: 'OnePlus/OnePlus7/OnePlus7:10/QKQ1.190716.003/1912141900:user/release-keys'
Revision: '0'
pid: 1790, tid: 2129, name: FMOD Studio upd >>> <<<
r0 00000000 r1 00000851 r2 00000006 r3 b7e21c48
r4 b7e21c5c r5 b7e21c40 r6 000006fe r7 0000016b
r8 b7e21c58 r9 b7e21c48 sl b7e21c78 fp b7e21c68
ip 00000851 sp b7e21c18 lr e8ba030f pc e8ba0322 cpsr b7e21928
backtrace:
06-02 13:37:24.917 1790-2129/? E/CRASH: #00 pc 0002b322 /apex/com.android.runtime/lib/bionic/libc.so (abort+4294799525)
#01 pc 00000143 /system/lib/libstdc++.so (__cxa_pure_virtual+4294963210)
#02 pc 00026b59 /data/app/com.-16no5PuPJcA_c7NaSncWUw==/lib/arm/libfmodstudioL.so
#03 pc 0003452f /data/app/com.-16no5PuPJcA_c7NaSncWUw==/lib/arm/libfmodstudioL.so
#04 pc 0003576b /data/app/com.-16no5PuPJcA_c7NaSncWUw==/lib/arm/libfmodstudioL.so
#05 pc 000475af /data/app/com.-16no5PuPJcA_c7NaSncWUw==/lib/arm/libfmodstudioL.so
#06 pc 0004a3d5 /data/app/com.-16no5PuPJcA_c7NaSncWUw==/lib/arm/libfmodstudioL.so
#07 pc 00053f15 /data/app/com.-16no5PuPJcA_c7NaSncWUw==/lib/arm/libfmodstudioL.so
#08 pc 000e2ea7 /data/app/com.16no5PuPJcA_c7NaSncWUw==/lib/arm/libfmodstudioL.so
#09 pc 000e4117 /data/app/com.-16no5PuPJcA_c7NaSncWUw==/lib/arm/libfmodstudioL.so
#10 pc 001130ef /data/app/com.-16no5PuPJcA_c7NaSncWUw==/lib/arm/libfmodstudioL.so
#11 pc 00113a41 /data/app/com.-16no5PuPJcA_c7NaSncWUw==/lib/arm/libfmodstudioL.so
#12 pc 00073451 /apex/com.android.runtime/lib/bionic/libc.so
#13 pc 0002c7c9 /apex/com.android.runtime/lib/bionic/libc.so
06-02 13:37:24.918 1790-2129/? E/CRASH: memory near r3:
b7e21c28 00000000 00000000 00000000 00000000 ................
b7e21c38 ffffffff 00000000 ffffffdf ffffffff ................
b7e21c48 00000000 00000000 ffffffff 000006fe ................
b7e21c58 000028c4 00000000 00000000 00000000 .(..............
b7e21c68 00000000 00000000 00000000 00000000 ................
b7e21c78 00000000 00000000 00000000 00000000 ................
b7e21c88 00000000 00000000 00000000 00000000 ................
b7e21c98 00000000 00000000 00000000 00000000 ................
b7e21ca8 00000000 00000000 00000000 00000000 ................
b7e21cb8 00000000 00000000 00000000 00000000 ................
b7e21cc8 473b8000 00000000 00000000 00000000 ..;G............
b7e21cd8 00000000 b571e908 b7e21d0c 00000000 ......q.........
b7e21ce8 b7e21d20 00000000 00000003 b7e21d58 ...........X...
06-02 13:37:24.919 1790-2129/? E/CRASH: b7e21cf8 00000000 e5d11147 b7e21d20 a71a7b5b ....G... ...[{..
b7e21d08 a7521c78 a1b1f308 00000000 a1b1f308 x.R.............
b7e21d18 a1b1f308 00000000 b7e21d40 a71b5533 ........@...3U..
memory near r4:
b7e21c3c 00000000 ffffffdf ffffffff 00000000 ................
b7e21c4c 00000000 ffffffff 000006fe 000028c4 .............(..
b7e21c5c 00000000 00000000 00000000 00000000 ................
b7e21c6c 00000000 00000000 00000000 00000000 ................
b7e21c7c 00000000 00000000 00000000 00000000 ................
b7e21c8c 00000000 00000000 00000000 00000000 ................
b7e21c9c 00000000 00000000 00000000 00000000 ................
b7e21cac 00000000 00000000 00000000 00000000 ................
b7e21cbc 00000000 00000000 00000000 473b8000 ..............;G
b7e21ccc 00000000 00000000 00000000 00000000 ................
b7e21cdc b571e908 b7e21d0c 00000000 b7e21d20 ..q......... ...
06-02 13:37:24.920 1790-2129/? E/CRASH: b7e21cec 00000000 00000003 b7e21d58 00000000 ........X.......
b7e21cfc e5d11147 b7e21d20 a71a7b5b a7521c78 G... ...[{..x.R.
b7e21d0c a1b1f308 00000000 a1b1f308 a1b1f308 ................
b7e21d1c 00000000 b7e21d40 a71b5533 00000000 ....@...3U......
b7e21d2c 048dba80 00000000 a1b1f308 00000000 ................
memory near r5:
b7e21c20 b7e21ca8 b7e21cb8 00000000 00000000 ................
b7e21c30 00000000 00000000 ffffffff 00000000 ................
b7e21c40 ffffffdf ffffffff 00000000 00000000 ................
b7e21c50 ffffffff 000006fe 000028c4 00000000 .........(......
b7e21c60 00000000 00000000 00000000 00000000 ................
b7e21c70 00000000 00000000 00000000 00000000 ................
b7e21c80 00000000 00000000 00000000 00000000 ................
b7e21c90 00000000 00000000 00000000 00000000 ................
b7e21ca0 00000000 00000000 00000000 00000000 ................
06-02 13:37:24.921 1790-2129/? E/CRASH: b7e21cb0 00000000 00000000 00000000 00000000 ................
b7e21cc0 00000000 00000000 473b8000 00000000 ..........;G....
b7e21cd0 00000000 00000000 00000000 b571e908 ..............q.
b7e21ce0 b7e21d0c 00000000 b7e21d20 00000000 ........ .......
b7e21cf0 00000003 b7e21d58 00000000 e5d11147 ....X.......G...
b7e21d00 b7e21d20 a71a7b5b a7521c78 a1b1f308 ...[{..x.R.....
b7e21d10 00000000 a1b1f308 a1b1f308 00000000 ................
memory near r8:
06-02 13:37:24.922 1790-2129/? E/CRASH: b7e21ca8 00000000 00000000 00000000 00000000 ................
b7e21d28 00000000 048dba80 00000000 a1b1f308 ................
memory near r9:
06-02 13:37:24.923 1790-2129/? E/CRASH: b7e21c68 00000000 00000000 00000000 00000000 ................
memory near sl:
06-02 13:37:24.924 1790-2129/? E/CRASH: b7e21c88 00000000 00000000 00000000 00000000 ................
b7e21d38 00000000 a1b1f3a8 b7e21db8 a71b676f ............og..
b7e21d48 a8216c30 00000011 b7e21d80 b7e21da8 0l!.............
memory near fp:
06-02 13:37:24.925 1790-2129/? E/CRASH: b7e21c68 00000000 00000000 00000000 00000000 ................
memory near sp:
06-02 13:37:24.926 1790-2129/? E/CRASH: b7e21bf8 00002780 0db2e95a b571e908 b7e21c40 .'..Z.....q.@...
b7e21c08 b571e908 b7e21c40 000006fe b7e21d20 ..q.@....... ...
b7e21c18 b7e21c88 b7e21c98 b7e21ca8 b7e21cb8 ................
06-02 13:37:24.927 1790-2129/? E/CRASH: b7e21cd8 00000000 b571e908 b7e21d0c 00000000 ......q.........
code around pc:
e8ba0300 f9088acf e9cd8acf f04f060e 2100eada ..........O....!
e8ba0310 60212206 90104639 464b4630 176bf240 ."!`9F..0FKF@.k.
e8ba0320 a904df00 460a4821 f9604478 f9420acd ....!H.FxD`...B.
e8ba0330 68000acd 20066010 f04f2200 2002ecf2 ...h.`. ."O....
e8ba0340 22004629 ec4cf04f f04f2014 4605ec5a )F."O.L.. O.Z..F
e8ba0350 f04f20e0 4606ec56 464c9803 8acff90a . O.V..F..LF....
e8ba0360 8acff900 f90b9802 f9008acf 98018acf ................
e8ba0370 8acff908 8acff900 f9009800 20148acf ...............
e8ba0380 8ac0f904 30fff04f 050ee9cd ea98f04f ....O..0....O...
e8ba0390 22062100 46316021 46289010 f240464b .!."!`1F..(FKF@.
e8ba03a0 df00176b f04f207f bf00ecc4 fffce68c k.... O.........
e8ba03b0 f04e2300 d4d4bd13 4c03b510 f8d4447c .#N........L|D..
e8ba03c0 e8bdc000 47604010 00051e00 4601460a .....@`G.....F.F
e8ba03d0 0063f06f f04e2300 d4d4bd07 b082b510 o.c..#N.........
e8ba03e0 4479490a 6821680c 46699101 ecb8f04f .IyD.h!h..iFO...
e8ba03f0 28009900 f04fbf08 980131ff 1a106822 ...(..O..1.."h..
code around lr:
e8ba02ec 8acff900 f9042014 f04f8ac0 f90a30ff ..... ....O..0..
e8ba02fc f90b8acf f9088acf e9cd8acf f04f060e ..............O.
e8ba030c 2100eada 60212206 90104639 464b4630 ...!."!`9F..0FKF
e8ba031c 176bf240 a904df00 460a4821 f9604478 @.k.....!H.FxD`.
e8ba032c f9420acd 68000acd 20066010 f04f2200 ..B....h.`. ."O.
e8ba033c 2002ecf2 22004629 ec4cf04f f04f2014 ... )F."O.L.. O.
e8ba034c 4605ec5a f04f20e0 4606ec56 464c9803 Z..F. O.V..F..LF
e8ba035c 8acff90a 8acff900 f90b9802 f9008acf ................
e8ba036c 98018acf 8acff908 8acff900 f9009800 ................
e8ba037c 20148acf 8ac0f904 30fff04f 050ee9cd ... ....O..0....
e8ba038c ea98f04f 22062100 46316021 46289010 O....!."!`1F..(F
e8ba039c f240464b df00176b f04f207f bf00ecc4 KF@.k.... O.....
e8ba03ac fffce68c f04e2300 d4d4bd13 4c03b510 .....#N........L
e8ba03bc f8d4447c e8bdc000 47604010 00051e00 |D.......@`G....
e8ba03cc 4601460a 0063f06f f04e2300 d4d4bd07 .F.Fo.c..#N.....
e8ba03dc b082b510 4479490a 6821680c 46699101 .....IyD.h!h..iF
06-02 13:37:24.936 1790-1912/? E/CRASH: other thread is trapped; signum = 6
06-02 13:37:24.936 1790-1912/? E/MessageQueue: IdleHandler threw exception
java.lang.Error: signal 6 (SIGABRT), code -6 (?), fault addr --------
Revision: '0'
at libc.abort(abort)
at libstdc++.__cxa_pure_virtual(__cxa_pure_virtual)
at libfmodstudioL.00026b59(Native Method)
at libfmodstudioL.0003452f(Native Method)
at libfmodstudioL.0003576b(Native Method)
at libfmodstudioL.000475af(Native Method)
at libfmodstudioL.0004a3d5(Native Method)
at libfmodstudioL.00053f15(Native Method)
at libfmodstudioL.000e2ea7(Native Method)
at libfmodstudioL.000e4117(Native Method)
at libfmodstudioL.001130ef(Native Method)
at libfmodstudioL.00113a41(Native Method)
at libc.00073451(Native Method)
at libc.0002c7c9(Native Method)
