When running on Oculus Go or Oculus Quest, am getting this fatal error.
This log is from the Oculus device itself. Build seems to show no errors.
Seems to be while loading banks. I’ve check the non-asset dir settings, reloaded banks, rebuilt the project… everything short of calling 911 for what may have been a panic attack disguised as a heart attack when nearing a deadline.
This is with UE4.23 btw. The app works perfectly fine without audio if i remove all traces of FMod. Also, the starting map does NOT trigger a sound at any point. I see a black screen (while it caches) and then back to Home Screen without any reasons or popups.
[2019.09.15-10.54.52:205][ 0]LogFMOD: Default sample rate = 24000
[2019.09.15-10.54.52:205][ 0]LogFMOD: System sample rate = 48000
[2019.09.15-10.54.52:205][ 0]LogFMOD: Warning: …/…/src/fmod_systemi.cpp(2808) - Output requires a sample rate of 48000Hz, resampling will occur.
[2019.09.15-10.54.52:205][ 0]LogFMOD: Loading Banks
[2019.09.15-10.54.52:205][ 0]LogAndroid: Error: === Critical error: ===
[2019.09.15-10.54.52:205][ 0]LogAndroid: Error: Assertion failed: IsValid() [File:D:/Unreal Engine/Source/UnrealEngine_GIT_4.23/Engine/Source/Runtime/Core/Public\Templates/SharedPointer.h] [Line: 840]
[2019.09.15-10.54.52:205][ 0]LogAndroid: Error: [Callstack] 0x00000000C560A34C libUE4.so(0x000000000420734C)!FDebug::CheckVerifyFailedImpl(char const*, char const*, int, char16_t const*, …) []
[2019.09.15-10.54.52:205][ 0]LogAndroid: Error: [Callstack] 0x00000000C5440F48 libUE4.so(0x000000000403DF48)!FAndroidPlatformFile::OpenRead(char16_t const*, bool, bool) []
[2019.09.15-10.54.52:205][ 0]LogAndroid: Error: [Callstack] 0x00000000C7706668 libUE4.so(0x0000000006303668)!FPakPlatformFile::OpenRead(char16_t const*, bool) []
[2019.09.15-10.54.52:206][ 0]LogAndroid: Error: [Callstack] 0x00000000C549F424 libUE4.so(0x000000000409C424)!FFileManagerGeneric::CreateFileReaderInternal(char16_t const*, unsigned int, unsigned int) []
[2019.09.15-10.54.52:206][ 0]LogAndroid: Error: [Callstack] 0x00000000C505DFF8 libUE4.so(0x0000000003C5AFF8)!FFMODFileSystem::OpenInternal(char const*, unsigned int*, void**) []
[2019.09.15-10.54.52:206][ 0]LogAndroid: Error: [Callstack] 0x00000000C505E8E0 libUE4.so(0x0000000003C5B8E0)!FFMODFileSystem::Run() []
[2019.09.15-10.54.52:206][ 0]LogAndroid: Error: [Callstack] 0x00000000C54EA454 libUE4.so(0x00000000040E7454)!FRunnableThreadPThread::Run() []
[2019.09.15-10.54.52:206][ 0]LogAndroid: Error: [Callstack] 0x00000000C54481DC libUE4.so(0x00000000040451DC)!FRunnableThreadPThread::_ThreadProc(void*) []
[2019.09.15-10.54.52:206][ 0]LogAndroid: Error: [Callstack] 0x00000000E796A8D4 libc.so(0x00000000000478D4)Unknown []
[2019.09.15-10.54.52:206][ 0]LogAndroid: Error: [Callstack] 0x00000000E793CFE6 libc.so(0x0000000000019FE6)Unknown []
