I want to loop an audio track a certain number of times in a timeline sheet. Is there any way?
Yes, it’s possible. There are a few different ways you could do it.
The simplest would be to use an instrument that’s set to loop with a finite play count of your choosing.
If you’d prefer to use timeline logic instead, you could use a loop region with a parameter trigger condition in conjunction with an increment parameter command instrument, to ensure the parameter’s value is incremented once each loop.
Yes, of course.
As I suggested in my above post, you should add a parameter trigger condition to the loop region, then place a command instrument somewhere inside the loop region and set its command to “increment parameter.” This will ensure the parameter’s value is incremented once each loop. If you set the parameter’s trigger condition such that it ceases being true after a certain number of loops, you’ll get the behavior you want.
Not there.
- In the editor, right-click on either the audio track or the master track, then select “Add Command Instrument” from the context menu.
This adds a purple command instrument to the track. - If the command instrument is not inside the loop region already, click and drag it inside the loop region.
- Click on the command instrument to select it.
This causes its properties to be displayed in the deck. - In the deck, set the command type property to “Increment Parameter.”
- Set the target property to the loopcontrol parameter.
- Set the delta value property to the number you want to increment that parameter by (probably 1).
That should get you the behavior you want.
i did it!!! thank you! And I’m sorry to bother you with such an elementary question
I’m glad to hear you could get it working!
That’s what this forum is for!
Hi there. Im trying to replicate the same situation, but i dont see the “loopcontrol” parameter. I need create a new parameter? Someone can share a screenshot please? Thanks!
The loopcontrol parameter can be seen in the screenshot that orang5648432 posted above.
You could create your own parameter, if you prefer. Either a continuous parameter or a discrete parameter would work.
