Ah thanks for the information - what operating system and resolution are you running at?
Oops, sorry! Of course:
MacOS 10.14.6 Mojave, 1920x1080.
We’ve reproduced the issue here and will be implementing a fix for a future version of studio.
The problem seems to most easily appear on dual monitor setups with different dpi settings on both monitors. For the time being, you may be able to work around it by having the same dpi settings on both monitors.
That’s great to know thanks!
My setup is a MacBook Pro with a Retina screen connected to 2 1920x1080 monitors. Indeed if I close the MacBook to put it in clamshell mode and start up Fmod, then the display issues are gone.
So that’s a work around if anybody has the same issue.
