In the process of upgrading Unity to 2019.4.36f1 (from 2019.4.27f1) ended up having to upgrade FMOD as well due to console SDK/GDK requirements to 2.01.15 (from 2.01.09) and was expecting a smooth and easy upgrade since its a relatively minor version increase but it was anything but.
Changes in EventManager.cs are broken and causes NRE on a clean cache and here is the “fixed” version:
// Get all banks and set cache time to most recent write time
List<string> bankFileNames = new List<string>();
DateTime lastWriteTime = DateTime.MinValue;
try
bankFileNames = new List<string>(Directory.GetFiles(defaultBankFolder, "*.bank", SearchOption.AllDirectories));
lastWriteTime = bankFileNames.Max(fileName => File.GetLastWriteTime(fileName));
catch
Anyway the latest issue I am running into is the fmodstudioL.dll seems to be missing from lib\win\x86_64 folder from the Downloaded 2.01.15 builds.
May you please update the build or provide a workaround?
