Did any of you use FMOD for your game? Do I need special binaries for the Switch? I am asking, because for windows I had to include some DLLs.
If I need binaries for Nintendo Switch, where can I find them?
I am using Godot Engine 3.5.
You do need special binaries for Switch. To enable access to the Switch downloads on fmod.com you need to register a project here : https://fmod.com/profile#projects and verify your Switch developer status with us by following the instructions here : https://fmod.com/profile#permissions.
You may also want to check if your version of Godot actually supports using FMOD for Switch.
Thanks Andrew, I am downloading it right now. ![]()
I think, someone already went though the process with Godot3 + FMOD for the Switch on a Discord server I am on. But I will find out soon, if it is possible I guess. ![]()
