Dynamic EQ in Fmod Studio
Hi!
Just in case I’m missing something, there isn’t any Dynamic EQ effect avaiable on Fmod Studio, right?
Would someone know such a plugin?
If not, I’ll try to use a free VST such as TDR Nova | Tokyo Dawn Records to make my own plugin, but I have to admit I’m a bit scared of the process!
(For the context: A lot of parts in my game’s soundtrack are a bit painful to the ears because of some high frequencies. Redoing all of them is not a possibility right now, and using something like the multiband EQ affects other correct parts of the stroundtrack, so after some research I came to the conclusion that a dynamic EQ would be what I need!)
There is no prebuilt dynamic EQ plugin but you could build one yourself with sidechain modulation on each band required of the multiband EQ. It won’t be as sophisticated as a standalone custom plugin but it might do the job good enough for what you need.
Whilst it is possible to load a VST using the Core API, this is not portable to other platforms nor guaranteed to work. I would recommend using the above solution to achieve your goals.
https://www.fmod.com/resources/documentation-studio?version=2.02&page=modulator-reference.html#sidechain-modulator
Thank you very much, I’ll have a look in that direction!
