The problem does not reproduce for FMOD v2.01.04 and Emscripten v2.0.1.
I’ve found that current Emscripten version used for FMOD is 1.39.11, which is outdated, so I think that is the issue. Is it going to be upgraded? Thanks!
Thank you for the answer. LLVM bitcode files are available only for the fastcomp backend, which is not supported by emscripten starting from version 2.0.0. When I try to install it, I recieve the following message:
The fastcomp backend is not getting new builds or releases. Please use the upstream llvm backend or use an older version than 2.0.0 (such as 1.40.1).
When I try to use upstrem backend, I receive the following error:
Typically the older version was ok, we’ll have to release a newer version with 2.0 for upstream, we’ve put this in for our next release. If you need a build urgently you can write to support@fmod.com
