Error occurred when using FMOD_FILE_OPENCALLBACK!!
I use the 1.1.11 version before and nothing wrong happened.
	FILE* file = NULL;
	fopen_s( &file, "Reign of the Septims.mp3", "rb" );  //read a file into the memory
	FMOD_CREATESOUNDEXINFO info;
	memset( &info, 0, sizeof( FMOD_CREATESOUNDEXINFO ) );
	info.cbsize = sizeof( FMOD_CREATESOUNDEXINFO );
	info.useropen = MyOpen;
	info.userclose = MyClose;
	info.userread = MyRead;
	info.userseek = MySeek;
system->createStream( (const char*)file, FMOD_DEFAULT, &info, &pTestSound1 );
//here's the callback
FMOD_RESULT F_CALLBACK MyOpen( const char* name, int unicode, unsigned int *fileSize, void** handle, void** userData )
	if ( name )
		FILE* pFile = (FILE*)name;
		fseek( pFile, 0, SEEK_END );
		*fileSize = ftell( pFile );
		fseek( pFile, 0, SEEK_SET );
		*handle = pFile;
		return FMOD_OK;
	return FMOD_ERR_INVALID_PARAM;
FMOD_RESULT F_CALLBACK MyClose( void* handle, void* userData )
	if ( !handle )
	fclose( ( FILE* )handle );
	return FMOD_OK;
FMOD_RESULT F_CALLBACK MyRead( void* handle, void* buffer, unsigned int sizebytes, unsigned int* bytesread, void* userData )
	size_t haveRead = fread( buffer, 1, sizebytes, ( FILE* )handle );
	*bytesread = (unsigned int)haveRead;
	return FMOD_OK;
FMOD_RESULT F_CALLBACK MySeek( void* handle, unsigned int pos, void* userData )
	fseek( ( FILE* )handle, pos, SEEK_SET );
	return FMOD_OK;
I switch to the 1.2.5 version recently and change void**userData to void*userData.
But Error Occurred!! Why? and how to fix it ?
I’m sorry, I do have a question but not for this reason. Shame on me.
//error occured when playing the sound
system->playSound( pTestSound1, ProxyMasterGroup, false, 0 );
It’s about this ProxyMasterGroup.
I ask a question about the masterchannelgroup->SetMute does not work before,so I create a proxychannelgroup add to masterchannelgroup.
Here’s how I get the proxychannelgoup. It’s nothing wrong in 1.1.11version.
				FMOD::Studio::ID busID = {0};
				FMOD_RESULT result = m_pFmodSystem->lookupBusID( "/ProxyMasterGroup",&busID );     //get my proxymastergroup
				if ( result != FMOD_OK )
					return false;
				FMOD::Studio::MixerStrip * mixer = new FMOD::Studio::MixerStrip;
				result = m_pFmodSystem->getMixerStrip( &busID, loadingMode, mixer );
					return false;
				result = mixer->getChannelGroup( &ProxyMasterGroup );
					return false;
mixer->release();   //this line caused the error
I’m sorry again.
So in the 1.2.5 version I can’t release the mixerstrip even though I just want the channelgroup in it?
Do you mean a compiler error? Have a look at FMOD_CREATESOUNDEXINFO struct again, you can see your members are fileuseropen, fileuserseek, etc, rather than just useropen/userseek/…
I do see that you probably saw that, if you changed void**userdata to void *userdata, which it is now.
Did you pass 0 to createStream? That can return an error with your code.
I used your code and did this, and it played the sound no problem.
FMOD_RESULT F_CALLBACK MyOpen( const char* name, int unicode, unsigned int *fileSize, void** handle, void* userData )
   if ( name )
      *handle = pFile;
      return FMOD_OK;
   if ( !handle )
   return FMOD_OK;
   return FMOD_OK;
   return FMOD_OK;
void main()
   FILE* file = NULL;
   FMOD::System *system;
   FMOD::Sound *pTestSound1;
   FMOD_RESULT result;
   result = FMOD::System_Create(&system);
   result = system->init(100, FMOD_INIT_NORMAL, 0);
   fopen_s( &file, "c:/media/waterfall.mp3", "rb" );  //read a file into the memory
   info.fileuseropen = MyOpen;
   info.fileuserclose = MyClose;
   info.fileuserread = MyRead;
   info.fileuserseek = MySeek;
   result = system->createStream( (const char*)file, FMOD_DEFAULT, &info, &pTestSound1 );
   result = result;
   system->playSound(pTestSound1, 0, false, 0);
   _getch();
Thanks for your reply.
That problem has been solved.I checked FMOD_CREATESOUNDEXINFO again,but the members are still useropen/userseek/… Maybe I used a old version.
sorry, the members are still called useropen/userseek etc, I am referring to 1.03.00 which is coming out soon.
