Lately, this warning is beeing shown on my Unity’s console every couple of seconds when executing.
I dont know what it is, what could be causing it or how it affects the application performance.
The whole message goes like this:
[FMOD] MultiInstrumentStrategy::setEndTime : Too long between System updates, looping playback errors detected.
UnityEngine.Debug:LogWarning(Object)
FMODUnity.RuntimeManager:DEBUG_CALLBACK(DEBUG_FLAGS, StringWrapper, Int32, StringWrapper, StringWrapper) (at Assets/Plugins/FMOD/RuntimeManager.cs:33)
Any ideas?
Thanks for reading
Is it possible that you are experiencing a low frame rate? FMOD’s system->update() should be called every (Unity) Update(), this is affected by the frame rate.
The lower it goes is about 250 fps on the Unity’s profiler, I don’t know what could be causing a lower eprformance on FMOD. I found out that some sounds aren’t playing with a event emitter, I supose is because of this.
This warning shouldn’t necessarily be a problem, the most that would happen here is that due to a slightly longer than expected update, some sounds may be kicked off or stopped slightly later than the scheduling would normally do.
Using the Studio Profiler to record a session may help shed some light on anything that may be causing this:
https://fmod.com/resources/documentation-unity?version=2.0&page=user-guide.html#connect-using-live-update
https://fmod.com/resources/documentation-studio?version=2.0&page=profiling.html
