we’re experiencing a deadlock in the editor after changing some looping sounds to use virtualisation (virtualize) and limit the number of playing events.
macOS 10.15.6, FMOD 2.00.11 and 2.00.12, Unity 2019.4.7.
The first time the Unity editor is played everything works as expected. When we stop and start playmode again the editor deadlocks and has to be force quit. FMOD in the editor is the cause of the deadlock.
When the first play is started the following message appears in the console when the scene starts;
[FMOD] DSPJobList::addJob : DSP JobList expanding job from 1024 entries to 2048 entries.
And when the first play is stopped the following message appears in the console;
hi Cameron, yep sure, I’ll see if I can extract a repro soon.
I found that reducing the sheer number of FMOD emitters using the virtualize setting in the scene made the deadlock go away. We probably had a 128+ emitters using the same virtualised event. We’ve since reduced the objects using those emitters in the scene and it happened to fix the deadlock along the way. There are now probably less than 100 emitters.
The basic setup is a listener moving through a bunch of vehicles using the virtualised emitter for a vehicle sound. The size/range of the emitter was ~12m as we only wanted the nearest few vehicles to make sound. The vehicles are on a movement loop so voice stealing didn’t work that well (oldest, furthest, etc) and virtualising the events was the way to go.
I found the deadlock in 2.00.11 and tried updating to 2.00.12 but no dice. One other thing to note is that due to needing to play video with audio elsewhere, Unity sound is enabled as well with a very low number of voices. This is probably unrelated and I would guess that somewhere Unity/FMOD is holding onto some memory that the domain reload when pressing play is having a problem with.
