I’m using Unity 5.1.2f1 with the 1.06.10 FMOD integration. I’ve got an issue where I want to have a crowd sound respond to the game score using start() on the appropriate sound event each time the score changes; however, in our game, the scene resets every time the score changes. Originally I told the script controlling the crowd reactions to DontDestroyOnLoad so they wouldn’t get cut off when the scene changes, but if I do this, the events won’t respond to the .start() method any time after the scene reloads for the first time (possibly because they are initialized in Unity’s void Start() call which doesn’t get called again). However, when I do reload the crowd objects on every scene, the sounds get interrupted on scene changes. Is there a way to make the events keep playing through scene changes without using DontDestroyOnLoad?
Here’s my script for thoroughness:
using UnityEngine;
using System.Collections;
using FMOD.Studio;
public class CrowdSound : MonoBehaviour {
public Transform playerOneSide;
public Transform playerTwoSide;
static FMOD.Studio.EventInstance crowdOneCheer;
static FMOD.Studio.ParameterInstance playerOneCheer;
static FMOD.Studio.EventInstance crowdOneBoo;
static FMOD.Studio.ParameterInstance playerOneBoo;
static FMOD.Studio.EventInstance crowdOneGasp;
static FMOD.Studio.ParameterInstance playerOneGasp;
static FMOD.Studio.EventInstance crowdTwoCheer;
static FMOD.Studio.ParameterInstance playerTwoCheer;
static FMOD.Studio.EventInstance crowdTwoBoo;
static FMOD.Studio.ParameterInstance playerTwoBoo;
static FMOD.Studio.EventInstance crowdTwoGasp;
static FMOD.Studio.ParameterInstance playerTwoGasp;
int newp1score = ScoreManager.scoreOne;
int oldp1score = ScoreManager.scoreOne;
int newp2score = ScoreManager.scoreTwo;
int oldp2score = ScoreManager.scoreTwo;
// Use this for initialization
void Start () {
// P1 CrowdCheer Setup
crowdOneCheer = FMOD_StudioSystem.instance.GetEvent("event:/Ambience/CrowdCheer");
if(crowdOneCheer.getParameter("Player", out playerOneCheer) != FMOD.RESULT.OK)
Debug.LogError("Player param not found");
return;
var attributes = FMOD.Studio.UnityUtil.to3DAttributes(playerOneSide.position);
crowdOneCheer.set3DAttributes(attributes);
playerOneCheer.setValue(1);
// P2 CrowdCheer Setup
crowdTwoCheer = FMOD_StudioSystem.instance.GetEvent("event:/Ambience/CrowdCheer");
if(crowdTwoCheer.getParameter("Player", out playerTwoCheer) != FMOD.RESULT.OK)
return;
attributes = FMOD.Studio.UnityUtil.to3DAttributes(playerTwoSide.position);
crowdTwoCheer.set3DAttributes(attributes);
playerTwoCheer.setValue(2);
// P1 CrowdBoo Setup
crowdOneBoo = FMOD_StudioSystem.instance.GetEvent("event:/Ambience/CrowdBoo");
if(crowdOneBoo.getParameter("Player", out playerOneBoo) != FMOD.RESULT.OK)
return;
crowdOneBoo.set3DAttributes(attributes);
playerOneBoo.setValue(1);
// P2 CrowdBoo Setup
crowdTwoBoo = FMOD_StudioSystem.instance.GetEvent("event:/Ambience/CrowdBoo");
if(crowdTwoBoo.getParameter("Player", out playerTwoBoo) != FMOD.RESULT.OK)
return;
crowdTwoBoo.set3DAttributes(attributes);
playerTwoBoo.setValue(2);
// P1 CrowdGasp Setup
crowdOneGasp = FMOD_StudioSystem.instance.GetEvent("event:/Ambience/CrowdGasp");
if(crowdOneGasp.getParameter("Player", out playerOneGasp) != FMOD.RESULT.OK)
return;
crowdOneGasp.set3DAttributes(attributes);
playerOneGasp.setValue(1);
// P2 CrowdGasp Setup
crowdTwoGasp = FMOD_StudioSystem.instance.GetEvent("event:/Ambience/CrowdGasp");
if(crowdTwoGasp.getParameter("Player", out playerTwoGasp) != FMOD.RESULT.OK)
return;
crowdTwoGasp.set3DAttributes(attributes);
playerTwoGasp.setValue(2);
//Debug.Log (playerOneCrowd != null);
void Update () {
// Cheer after P1 Scores
if((newp1score > oldp1score) && newp1score < 2)
PlayCheer (1);
} else if ((newp1score > oldp1score) && newp1score == 2)
PlayGasp (1);
PlayGasp (2);
// Cheer after P2 scores
if((newp2score > oldp2score) && newp2score < 2)
PlayCheer (2);
} else if ((newp2score > oldp2score) && newp2score == 2)
PlayGasp (1);
PlayGasp (2);
// Boo after P2 Scores
if((newp1score < oldp1score))
PlayBoo (1);
else if ((newp1score < oldp1score) && newp1score < -1)
PlayGasp (1);
PlayGasp (2);
if((newp2score < oldp2score))
PlayBoo (2);
else if ((newp2score < oldp2score) && newp2score < -1)
PlayGasp (1);
PlayGasp (2);
oldp1score = newp1score;
oldp2score = newp2score;
public static void PlayCheer(int player)
if(player == 1)
crowdOneCheer.start ();
} else{
crowdTwoCheer.start ();
public static void PlayBoo(int player)
if(player == 1)
crowdOneBoo.start();
} else{
crowdTwoBoo.start ();
public static void PlayGasp(int player)
if(player == 1)
crowdOneGasp.start ();
} else{
crowdTwoGasp.start ();
void OnDestroy()
if(crowdOneCheer != null)
crowdOneCheer.stop(STOP_MODE.ALLOWFADEOUT);
crowdOneCheer.release();
if(crowdTwoCheer != null)
crowdTwoCheer.stop(STOP_MODE.ALLOWFADEOUT);
crowdTwoCheer.release();
if(crowdOneBoo != null)
crowdOneBoo.stop(STOP_MODE.ALLOWFADEOUT);
crowdOneBoo.release();
if(crowdTwoBoo != null)
crowdTwoBoo.stop(STOP_MODE.ALLOWFADEOUT);
crowdTwoBoo.release();
if(crowdOneGasp != null)
crowdOneGasp.stop(STOP_MODE.ALLOWFADEOUT);
crowdOneGasp.release();
if(crowdTwoGasp != null)
crowdTwoGasp.stop(STOP_MODE.ALLOWFADEOUT);
crowdTwoGasp.release();
