Hi all
I’m at my wits end here I’m afraid, really need help
I’ve done some FMOD before in C++, never had any issues, great middleware. However using it in Unity has been really difficult. I just can’t figure out how to deal with scene changes: when I change scene from a script Unity freezes and then crash. This doesn’t happen every time, but it happens enough to be a criticial issue. The stack trace (bottom) seems to suggest that FMOD is the culprit, and indeed when I remove all my FMOD listeners and emitters everything works fine with no crashes.
I need the soundscape to persist between scenes, so I use DontDestroyOnLoad on my listener object. However for testing I’ve put a listener in each scene, disabled by default. Another script on the same object activates it if it is the first on around:
void Awake()
// There can only be one !
if(__chosenOne == null)
// *I* am the milkman (my milk is delicious)
__chosenOne = this;
// Only ever have one FMOD_Listener active at a time!
GetComponent<FMOD_Listener>().enabled = true;
// This one should remain
DontDestroyOnLoad(this.gameObject);
else
// Seppuku!
Destroy(this.gameObject);
This isn’t working though: it breaks the sound, I get null-reference and/or “the requested event, bus or vca was not found” errors. My previous version didn’t break the sound, but didn’t stop the crash either:
void OnEnable()
foreach(SympathyFMOD_Listener other in FindObjectsOfType(typeof(SympathyFMOD_Listener)))
if(other != this)
Destroy(other.gameObject);
DontDestroyOnLoad(gameObject);
So basically my choice right now, and this is after months of development and due-dates being pushed back, is between no sound or a high probability of the application crashing whenever I change scenes. Please help :o
I’m using a version of the plugin from late last-year when development started.
========== OUTPUTING STACK TRACE ==================
(0x6B64137C) (fmodstudio): (filename not available): FMOD_Studio_EventInstance_GetPlaybackState + 0x1c
(0x0AE85039) (Mono JIT code): (filename not available): (wrapper managed-to-native) FMOD.Studio.EventInstance:FMOD_Studio_EventInstance_GetPlaybackState (intptr,FMOD.Studio.PLAYBACK_STATE&) + 0x69 (0AE84FD0 0AE8509B) [05846BD0 - Unity Child Domain] + 0x0
(0x0AE84FB3) (Mono JIT code): (filename not available): FMOD.Studio.EventInstance:getPlaybackState (FMOD.Studio.PLAYBACK_STATE&) + 0x2b (0AE84F88 0AE84FBE) [05846BD0 - Unity Child Domain] + 0x0
(0x0AE84F2F) (Mono JIT code): (filename not available): FMOD_StudioEventEmitter:getPlaybackState () + 0x9f (0AE84E90 0AE84F77) [05846BD0 - Unity Child Domain] + 0x0
(0x0AE84D8F) (Mono JIT code): (filename not available): FMOD_StudioEventEmitter:OnDestroy () + 0x8f (0AE84D00 0AE84E67) [05846BD0 - Unity Child Domain] + 0x0
(0x0904BE1F) (Mono JIT code): (filename not available): (wrapper runtime-invoke) object:runtime_invoke_void__this__ (object,intptr,intptr,intptr) + 0x8f (0904BD90 0904BEEA) [05846BD0 - Unity Child Domain] + 0x0
(0x09E0FEDE) c:\buildslave\monoandruntimeclasslibs\build\mono\mini\mini.c (4889 + 0xc): mono_jit_runtime_invoke + 0x214
(0x09D7D680) c:\buildslave\monoandruntimeclasslibs\build\mono\metadata\object.c (2618 + 0x10): mono_runtime_invoke + 0x51
(0x00706EF8) c:\buildagent\work\d3d49558e4d408f4\runtime\scripting\backend\mono\scriptingbackendapi_mono.cpp (183 + 0x1a): scripting_method_invoke + 0xb8
(0x00826C78) c:\buildagent\work\d3d49558e4d408f4\runtime\scripting\backend\scriptinginvocation.cpp (115 + 0x0): ScriptingInvocation::Invoke + 0x58
(0x0082716E) c:\buildagent\work\d3d49558e4d408f4\runtime\scripting\backend\scriptinginvocation.cpp (99 + 0x0): ScriptingInvocation::Invoke + 0xe
(0x008271DC) c:\buildagent\work\d3d49558e4d408f4\runtime\scripting\backend\scriptinginvocationnoargs.cpp (120 + 0x13): ScriptingInvocationNoArgs::InvokeChecked + 0x2c
(0x006F2300) c:\buildagent\work\d3d49558e4d408f4\runtime\mono\monobehaviour.cpp (347 + 0x0): MonoBehaviour::CallMethodInactive + 0xa0
(0x006F2811) c:\buildagent\work\d3d49558e4d408f4\runtime\mono\monobehaviour.cpp (294 + 0x0): MonoBehaviour::WillDestroyComponent + 0xb1
(0x007D2777) c:\buildagent\work\d3d49558e4d408f4\runtime\misc\gameobjectutility.cpp (990 + 0x0): PreDestroyRecursive + 0x67
(0x007D2824) c:\buildagent\work\d3d49558e4d408f4\runtime\misc\gameobjectutility.cpp (998 + 0x40): PreDestroyRecursive + 0x114
(0x007D2C24) c:\buildagent\work\d3d49558e4d408f4\runtime\misc\gameobjectutility.cpp (1054 + 0x11): DestroyGameObjectHierarchy + 0x24
(0x007D328D) c:\buildagent\work\d3d49558e4d408f4\runtime\misc\gameobjectutility.cpp (1200 + 0x6): DestroyObjectHighLevel + 0x4fd
(0x0081855E) c:\buildagent\work\d3d49558e4d408f4\runtime\misc\sceneunloading.cpp (40 + 0x7): UnloadGameScene + 0x11e
(0x007DE7D4) c:\buildagent\work\d3d49558e4d408f4\runtime\misc\player.cpp (1330 + 0x0): LevelLoading::LoadLevel + 0x264
(0x007DEA29) c:\buildagent\work\d3d49558e4d408f4\runtime\misc\player.cpp (372 + 0x0): PlayerLoadLevelFromThread + 0x19
(0x007DF389) c:\buildagent\work\d3d49558e4d408f4\runtime\misc\preloadmanager.cpp (780 + 0x0): PreloadLevelOperation::IntegrateMainThread + 0xc9
(0x007E0F04) c:\buildagent\work\d3d49558e4d408f4\runtime\misc\preloadmanager.cpp (471 + 0x0): PreloadManager::UpdatePreloadingSingleStep + 0x134
(0x007E1160) c:\buildagent\work\d3d49558e4d408f4\runtime\misc\preloadmanager.cpp (534 + 0x0): PreloadManager::WaitForAllAsyncOperationsToComplete + 0x50
(0x007E1239) c:\buildagent\work\d3d49558e4d408f4\runtime\misc\preloadmanager.cpp (564 + 0x0): PreloadManager::UpdatePreloading + 0x99
(0x007DD577) c:\buildagent\work\d3d49558e4d408f4\runtime\misc\player.cpp (1771 + 0x0): PlayerLoop + 0x197
(0x00F654FC) c:\buildagent\work\d3d49558e4d408f4\editor\src\application.cpp (2286 + 0xb): Application::UpdateScene + 0x21c
(0x00F69577) c:\buildagent\work\d3d49558e4d408f4\editor\src\application.cpp (2216 + 0x0): Application::UpdateSceneIfNeeded + 0x37
(0x0100C682) c:\buildagent\work\d3d49558e4d408f4\editor\platform\windows\wineditormain.cpp (336 + 0x0): MainMessageLoop + 0x1c2
(0x0100D5C7) c:\buildagent\work\d3d49558e4d408f4\editor\platform\windows\wineditormain.cpp (848 + 0x0): WinMain + 0xe37
(0x01125C34) f:\dd\vctools\crt_bld\self_x86\crt\src\crt0.c (275 + 0x1c): __tmainCRTStartup + 0x11a
(0x7606336A) (kernel32): (filename not available): BaseThreadInitThunk + 0x12
(0x77C29F72) (ntdll): (filename not available): RtlInitializeExceptionChain + 0x63
(0x77C29F45) (ntdll): (filename not available): RtlInitializeExceptionChain + 0x36
========== END OF STACKTRACE ===========
