Events not showing up in FMOD (Skill Tree)
@SkillTree_FMOD
I’m following the Skill Tree course for FMOD.
`Live Update On` shows for me and I'm in the room with the moving Orb.
When I record I expect to see this:
But I get this:
(And opening them with the white triangle doesn’t reveal them either).
I’m using Fmod 2.03.15 on Mac OS 15.6.
I hope someone can help.
Hey there!
So at the very top you have the different graphs you can select to change the view of the data. The first image you posted has ‘Levels’ selected, whereas your second image i suspect has one of the two ‘Instances’ graphs selected.
In any case, on the ‘Profiler’ lesson there is an instruction to switch to the ‘Lifespans’ view which allows us to see each instance of an Event along the recorded timeline.
thank you
