Hi guys getting this message when I try to build the fmod session for a unity game. Failed to encode bank “Master Bank” due the following error: The format of the source file is invalid.
Im guessing it due to the fact that the fmod session was recovered from a broken laptop, any suggestions? cheers
This error may occur when trying to either encode an asset that is not supported or when trying to encode it into a format that doesn’t have all of its dependencies (eg. AT9).
Do you have any more information such as the assets you are trying to build into the bank, the format you are encoding to, and the location you are building to?
Hi, are you still getting the error when building banks?
