Failed to open file (bank location)
Hello, after a while of FMOD working fine ive run into a peculiar issue, where FMOD is only able to access one of my parameters. The code I am using to refer to the parameter that wont load is identical, so Im confused as to why it isnt working. It looks like there is a \ instead of a / before Desktop/Car Engines, could that be the issue?
Here is my code:
using System.Collections;
using UnityEngine;
public class What : MonoBehaviour
    FMOD.Studio.EventInstance EngineSounds;
    FMOD.Studio.EventInstance GravelSounds;
    //FMOD.Studio.EventDescription engineDesc;
    FMOD.Studio.PARAMETER_DESCRIPTION pd;
    FMOD.Studio.PARAMETER_DESCRIPTION Apd;
    FMOD.Studio.PARAMETER_DESCRIPTION Spd;
    FMOD.Studio.PARAMETER_ID SpID;
    FMOD.Studio.PARAMETER_ID pID;
    FMOD.Studio.PARAMETER_ID ApID;
    public bool turboFart;
    [Range(0.0f, 1.0f)]
    public float RPM;
    public bool input;
    public float inputVal;
    //[FMODUnity.EventRef]
    //public string eSounds;
    [Header("Dust Trails")]
    public ParticleSystem pSys1;
    public ParticleSystem pSys2;
    public bool includeChildren = true;
    public bool isEmitting;
    [Header("Object with vehicle script")]
    public float velocity;
    //public GameObject car;
    public MSVehicleControllerFree vehicleControl;
    public void Start()
        EngineSounds = FMODUnity.RuntimeManager.CreateInstance("event:/EngineSounds");
        GravelSounds = FMODUnity.RuntimeManager.CreateInstance("event:/Gravel Sounds");
        EngineSounds.start();
        GravelSounds.start();
        FMODUnity.RuntimeManager.StudioSystem.getParameterDescriptionByName("RPM", out pd);
        pID = pd.id;
        FMODUnity.RuntimeManager.StudioSystem.getParameterDescriptionByName("Input", out Apd);
        ApID = Apd.id;
        FMODUnity.RuntimeManager.StudioSystem.getParameterDescriptionByName("Input", out Spd);
        SpID = Spd.id;
        EngineSounds.release();
        GravelSounds.release();
    void Update()
        velocity = vehicleControl.velxCurrentRPM;
        EngineSounds.set3DAttributes(FMODUnity.RuntimeUtils.To3DAttributes(gameObject));
        GravelSounds.set3DAttributes(FMODUnity.RuntimeUtils.To3DAttributes(gameObject));
        input = Input.GetKey(KeyCode.W);
        RPM = vehicleControl.pitchAUD - 0.85f;
        if (!turboFart)
            inputVal = Input.GetAxis("Vertical");
        else
            inputVal = 0f;
        FMODUnity.RuntimeManager.StudioSystem.setParameterByID(SpID, velocity);
        FMODUnity.RuntimeManager.StudioSystem.setParameterByID(pID, RPM);
        FMODUnity.RuntimeManager.StudioSystem.setParameterByID(ApID, inputVal);
        if (vehicleControl.sidewaysSlipMaxSkid > 0.5f)
            if (inputVal >= 0.5f)
                FMODUnity.RuntimeManager.StudioSystem.setParameterByID(pID, RPM + 0.25f);
        turboFart = vehicleControl.turboFart;
        var emission1 = pSys1.emission;
        var emission2 = pSys2.emission;
        if (velocity >= 30f)
            pSys1.Play(); emission1.enabled = true; // Applies the new value directly to the Particle System
            pSys2.Play(); emission2.enabled = true;
            //var emission = pSys1.
            isEmitting = true;
        } else
            pSys1.Stop(); emission1.enabled = false; // Applies the new value directly to the Particle System
            pSys2.Stop(); emission2.enabled = false;
            isEmitting = false;
(Sorry if its messy, havent gotten around to cleaning up the commented out code)
Could I grab some info:
What version of Unity, FMOD Studio, and integration are you using?
It could be worth rebuilding the Desktop build folder. Simply delete the folder and rebuild it in FMOD Studio.
