FMOD 2.03.12 Crashes Upon Starting
FMOD 2.03.12 crashes every time I open it, no matter where its opened from. If I try to open it from Unity, the loading window gets stuck at 99% or 100%, and if I try to open it externally from my start menu, nothing happens and the process sits at 0% CPU usage in task manager.
I’ve seen another post that talked about having the same issue where the solution was to change the location of the plugins folder in local appdata in some way, but not only do I not have any FMOD plugins in the first place, when I move the folder to another place another one is created upon me attempting to load FMOD again.
I don’t have an option to launch FMOD in safe mode because the app never starts. I’ve tried reinstalling FMOD like 3 separate times and it does nothing. Restarting my computer does nothing, and running as administrator does nothing. This is incredibly frustrating
Thank you for bringing this to our attention, is the happening with any other version of 2.03?
I haven’t tried, since 2.03.12 is the only version relevant to and necessary for the projects I’m working on at the moment
Could I please grab the most recent log files from: AppData\Local\FMOD Studio\Logs?
A lot of my logs are completely blank, and I think that may be the difference between attempting to open FMOD on its own vs from a project file. I can’t upload text files as a new user but here’s a couple from last night. From the ones I’ve looked at, my logs seem to be mostly identical.
  2026-02-11 00:57:52 Operating System: Windows 11 Version 22H2; x86_64
  2026-02-11 00:57:52 Client ID: {e84bf153-30cb-4892-80b4-a5e2b9e74e12}
- 2026-02-11 00:57:52 [Initialize Sound System 0x000002e3c9e4e200]: Time started
  2026-02-11 00:57:52 Loaded plugin library "AudioGaming AudioMotors" (type 2) from C:/Program Files/FMOD SoundSystem/FMOD Studio 2.03.12/Plugins/audiogaming_audiomotors.dll
  2026-02-11 00:57:52 AudioGaming AudioMotors #0: "Drive" (type 0)
  2026-02-11 00:57:52 AudioGaming AudioMotors #1: "RPM" (type 0)
  2026-02-11 00:57:52 AudioGaming AudioMotors #2: "Transpose" (type 0)
  2026-02-11 00:57:52 AudioGaming AudioMotors #3: "Randomize" (type 0)
  2026-02-11 00:57:52 AudioGaming AudioMotors #4: "Adapt" (type 0)
  2026-02-11 00:57:52 AudioGaming AudioMotors #5: "Volume" (type 0)
  2026-02-11 00:57:52 AudioGaming AudioMotors #6: "Format" (type 1)
  2026-02-11 00:57:52 AudioGaming AudioMotors #7: "Car Data" (type 3)
  2026-02-11 00:57:52 AudioGaming AudioMotors #8: "Range" (type 0)
  2026-02-11 00:57:52 AudioGaming AudioMotors #9: "Sync" (type 1)
  2026-02-11 00:57:52 AudioGaming AudioMotors #10: "Mode" (type 1)
  2026-02-11 00:57:52 Loaded plugin library "AudioGaming AudioRain" (type 2) from C:/Program Files/FMOD SoundSystem/FMOD Studio 2.03.12/Plugins/audiogaming_audiorain.dll
  2026-02-11 00:57:52 AudioGaming AudioRain #0: "GlobalGain" (type 0)
  2026-02-11 00:57:52 AudioGaming AudioRain #1: "GlobalStrength" (type 0)
  2026-02-11 00:57:52 AudioGaming AudioRain #2: "AutoToManual" (type 0)
  2026-02-11 00:57:52 AudioGaming AudioRain #3: "GlobalMax" (type 0)
  2026-02-11 00:57:52 AudioGaming AudioRain #4: "GlobalRate" (type 0)
  2026-02-11 00:57:52 AudioGaming AudioRain #5: "GlobalAttack" (type 0)
  2026-02-11 00:57:52 AudioGaming AudioRain #6: "GlobalMin" (type 0)
  2026-02-11 00:57:52 AudioGaming AudioRain #7: "RumbleLevel" (type 0)
  2026-02-11 00:57:52 AudioGaming AudioRain #8: "RumbleDensity" (type 0)
  2026-02-11 00:57:52 AudioGaming AudioRain #9: "RumbleNotchQ" (type 0)
  2026-02-11 00:57:52 AudioGaming AudioRain #10: "RumbleHiCut" (type 0)
  2026-02-11 00:57:52 AudioGaming AudioRain #11: "RumbleLoCut" (type 0)
  2026-02-11 00:57:52 AudioGaming AudioRain #12: "RumbleCoupl" (type 0)
  2026-02-11 00:57:52 AudioGaming AudioRain #13: "ShowerLevel" (type 0)
  2026-02-11 00:57:52 AudioGaming AudioRain #14: "ShowerColor" (type 0)
  2026-02-11 00:57:52 AudioGaming AudioRain #15: "ShowerLoCut" (type 0)
  2026-02-11 00:57:52 AudioGaming AudioRain #16: "ShowerHiCut" (type 0)
  2026-02-11 00:57:52 AudioGaming AudioRain #17: "Liquid1Level" (type 0)
  2026-02-11 00:57:52 AudioGaming AudioRain #18: "Liquid1Density" (type 0)
  2026-02-11 00:57:52 AudioGaming AudioRain #19: "Liquid1Color" (type 0)
  2026-02-11 00:57:52 AudioGaming AudioRain #20: "Liquid1Visc" (type 0)
  2026-02-11 00:57:52 AudioGaming AudioRain #21: "Liquid1Min" (type 0)
  2026-02-11 00:57:52 AudioGaming AudioRain #22: "Liquid1Max" (type 0)
  2026-02-11 00:57:52 AudioGaming AudioRain #23: "Liquid1LoCut" (type 0)
  2026-02-11 00:57:52 AudioGaming AudioRain #24: "Liquid1HiCut" (type 0)
  2026-02-11 00:57:52 AudioGaming AudioRain #25: "Liquid2Level" (type 0)
  2026-02-11 00:57:52 AudioGaming AudioRain #26: "Liquid2Density" (type 0)
  2026-02-11 00:57:52 AudioGaming AudioRain #27: "Liquid2Color" (type 0)
  2026-02-11 00:57:52 AudioGaming AudioRain #28: "Liquid2Visc" (type 0)
  2026-02-11 00:57:52 AudioGaming AudioRain #29: "Liquid2Min" (type 0)
  2026-02-11 00:57:52 AudioGaming AudioRain #30: "Liquid2Max" (type 0)
  2026-02-11 00:57:52 AudioGaming AudioRain #31: "Liquid2LoCut" (type 0)
  2026-02-11 00:57:52 AudioGaming AudioRain #32: "Liquid2HiCut" (type 0)
  2026-02-11 00:57:52 AudioGaming AudioRain #33: "LFE" (type 0)
  2026-02-11 00:57:52 AudioGaming AudioRain #34: "LFECut" (type 0)
  2026-02-11 00:57:52 AudioGaming AudioRain #35: "Format" (type 1)
  2026-02-11 00:57:52 Loaded plugin library "AudioGaming AudioWeather" (type 2) from C:/Program Files/FMOD SoundSystem/FMOD Studio 2.03.12/Plugins/audiogaming_audioweather.dll
  2026-02-11 00:57:52 AudioGaming AudioWeather #0: "Wind" (type 0)
  2026-02-11 00:57:52 AudioGaming AudioWeather #1: "Rain" (type 0)
  2026-02-11 00:57:52 AudioGaming AudioWeather #2: "Volume" (type 0)
  2026-02-11 00:57:52 AudioGaming AudioWeather #3: "Weather Type" (type 1)
  2026-02-11 00:57:52 AudioGaming AudioWeather #4: "Format" (type 1)
  2026-02-11 00:57:52 Loaded plugin library "AudioGaming AudioWind" (type 2) from C:/Program Files/FMOD SoundSystem/FMOD Studio 2.03.12/Plugins/audiogaming_audiowind.dll
  2026-02-11 00:57:52 AudioGaming AudioWind #0: "GlobalGain" (type 0)
  2026-02-11 00:57:52 AudioGaming AudioWind #1: "GlobalSpeed" (type 0)
  2026-02-11 00:57:52 AudioGaming AudioWind #2: "AutoToManual" (type 0)
  2026-02-11 00:57:52 AudioGaming AudioWind #3: "GlobalMax" (type 0)
  2026-02-11 00:57:52 AudioGaming AudioWind #4: "GlobalRate" (type 0)
  2026-02-11 00:57:52 AudioGaming AudioWind #5: "GlobalAttack" (type 0)
  2026-02-11 00:57:52 AudioGaming AudioWind #6: "GlobalMin" (type 0)
  2026-02-11 00:57:52 AudioGaming AudioWind #7: "BackflowLevel" (type 0)
  2026-02-11 00:57:52 AudioGaming AudioWind #8: "BackflowShape" (type 1)
  2026-02-11 00:57:52 AudioGaming AudioWind #9: "BackflowFilter" (type 1)
  2026-02-11 00:57:52 AudioGaming AudioWind #10: "BackflowFreq" (type 0)
  2026-02-11 00:57:52 AudioGaming AudioWind #11: "BackflowQ" (type 0)
  2026-02-11 00:57:52 AudioGaming AudioWind #12: "BackflowRate" (type 0)
  2026-02-11 00:57:52 AudioGaming AudioWind #13: "VariationRange" (type 0)
  2026-02-11 00:57:52 AudioGaming AudioWind #14: "BackflowLoCut" (type 0)
  2026-02-11 00:57:52 AudioGaming AudioWind #15: "BackflowHiCut" (type 0)
  2026-02-11 00:57:52 AudioGaming AudioWind #16: "BackflowCoupl" (type 0)
  2026-02-11 00:57:52 AudioGaming AudioWind #17: "WhistlingLevel" (type 0)
  2026-02-11 00:57:52 AudioGaming AudioWind #18: "WhistlingShape" (type 1)
  2026-02-11 00:57:52 AudioGaming AudioWind #19: "WhistlingQ" (type 0)
  2026-02-11 00:57:52 AudioGaming AudioWind #20: "WhistlingFloor" (type 0)
  2026-02-11 00:57:52 AudioGaming AudioWind #21: "WhistlingRate" (type 0)
  2026-02-11 00:57:52 AudioGaming AudioWind #22: "WhistlingFmin" (type 0)
  2026-02-11 00:57:52 AudioGaming AudioWind #23: "WhistlingFmax" (type 0)
  2026-02-11 00:57:52 AudioGaming AudioWind #24: "WhistlingPres" (type 0)
  2026-02-11 00:57:52 AudioGaming AudioWind #25: "WhistlingLoCut" (type 0)
  2026-02-11 00:57:52 AudioGaming AudioWind #26: "WhistlingHiCut" (type 0)
  2026-02-11 00:57:52 AudioGaming AudioWind #27: "WhistlingCoupl" (type 0)
  2026-02-11 00:57:52 AudioGaming AudioWind #28: "GustsLevel" (type 0)
  2026-02-11 00:57:52 AudioGaming AudioWind #29: "GustsShape" (type 1)
  2026-02-11 00:57:52 AudioGaming AudioWind #30: "GustsMax" (type 0)
  2026-02-11 00:57:52 AudioGaming AudioWind #31: "GustsRate" (type 0)
  2026-02-11 00:57:52 AudioGaming AudioWind #32: "GustsAttack" (type 0)
  2026-02-11 00:57:52 AudioGaming AudioWind #33: "GustsMin" (type 0)
  2026-02-11 00:57:52 AudioGaming AudioWind #34: "GustsLoCut" (type 0)
  2026-02-11 00:57:52 AudioGaming AudioWind #35: "GustsHiCut" (type 0)
  2026-02-11 00:57:52 AudioGaming AudioWind #36: "GustsCoupl" (type 0)
  2026-02-11 00:57:52 AudioGaming AudioWind #37: "SquallsLevel" (type 0)
  2026-02-11 00:57:52 AudioGaming AudioWind #38: "SquallsShape" (type 1)
  2026-02-11 00:57:52 AudioGaming AudioWind #39: "SquallsAmp" (type 0)
  2026-02-11 00:57:52 AudioGaming AudioWind #40: "SquallsRate" (type 0)
  2026-02-11 00:57:52 AudioGaming AudioWind #41: "SquallsFloor" (type 0)
  2026-02-11 00:57:52 AudioGaming AudioWind #42: "SquallsLoCut" (type 0)
  2026-02-11 00:57:52 AudioGaming AudioWind #43: "SquallsHiCut" (type 0)
  2026-02-11 00:57:52 AudioGaming AudioWind #44: "SquallsCoupl" (type 0)
  2026-02-11 00:57:52 AudioGaming AudioWind #45: "LFE" (type 0)
  2026-02-11 00:57:52 AudioGaming AudioWind #46: "LFECut" (type 0)
  2026-02-11 00:57:52 AudioGaming AudioWind #47: "Format" (type 1)
  2026-02-11 00:57:52 Loaded plugin library "FMOD Haptics" (type 2) from C:/Program Files/FMOD SoundSystem/FMOD Studio 2.03.12/Plugins/fmod_haptics.dll
  2026-02-11 00:57:52 FMOD Haptics #0: "Clip" (type 3)
  2026-02-11 00:57:52 FMOD Haptics #1: "Finite Length" (type 3)
  2026-02-11 00:57:52 FMOD Haptics #2: "Intensity Left" (type 0)
  2026-02-11 00:57:52 FMOD Haptics #3: "Intensity Right" (type 0)
  2026-02-11 00:57:52 Loaded plugin library "FMOD Controller Output" (type 0) from C:/Program Files/FMOD SoundSystem/FMOD Studio 2.03.12/Plugins/fmod_output_controller.dll
  2026-02-11 00:57:52 Loaded plugin library "Resonance Audio Listener" (type 2) from C:/Program Files/FMOD SoundSystem/FMOD Studio 2.03.12/Plugins/resonanceaudio.dll
  2026-02-11 00:57:52 Resonance Audio Listener #0: "Gain" (type 0)
  2026-02-11 00:57:52 Resonance Audio Listener #1: "Room Properties" (type 3)
  2026-02-11 00:57:52 Loaded plugin library "Resonance Audio Soundfield" (type 2) from C:/Program Files/FMOD SoundSystem/FMOD Studio 2.03.12/Plugins/resonanceaudio.dll
  2026-02-11 00:57:52 Resonance Audio Soundfield #0: "Gain" (type 0)
  2026-02-11 00:57:52 Resonance Audio Soundfield #1: "3D Attributes" (type 3)
  2026-02-11 00:57:52 Resonance Audio Soundfield #2: "Overall Gain" (type 3)
  2026-02-11 00:57:52 Loaded plugin library "Resonance Audio Source" (type 2) from C:/Program Files/FMOD SoundSystem/FMOD Studio 2.03.12/Plugins/resonanceaudio.dll
  2026-02-11 00:57:52 Resonance Audio Source #0: "Gain" (type 0)
  2026-02-11 00:57:52 Resonance Audio Source #1: "Spread" (type 0)
  2026-02-11 00:57:52 Resonance Audio Source #2: "Dist Rolloff" (type 1)
  2026-02-11 00:57:52 Resonance Audio Source #3: "Occlusion" (type 0)
  2026-02-11 00:57:52 Resonance Audio Source #4: "Directivity" (type 0)
  2026-02-11 00:57:52 Resonance Audio Source #5: "Dir Sharpness" (type 0)
  2026-02-11 00:57:52 Resonance Audio Source #6: "Attenuation Ran" (type 3)
  2026-02-11 00:57:52 Resonance Audio Source #7: "3D Attributes" (type 3)
  2026-02-11 00:57:52 Resonance Audio Source #8: "Bypass Room" (type 2)
  2026-02-11 00:57:52 Resonance Audio Source #9: "Near-Field FX" (type 2)
  2026-02-11 00:57:52 Resonance Audio Source #10: "Near-Field Gain" (type 0)
  2026-02-11 00:57:52 Resonance Audio Source #11: "Overall Gain" (type 3)
- 2026-02-11 00:57:52 [Initialize Sound System 0x000002e3c9e4e200]: Time taken is 30.29ms (0.030s)
- 2026-02-11 00:57:52 [Total Load]: Time started
- 2026-02-11 00:57:52 [Opening]: Time started
- 2026-02-11 00:57:52 [Create mappers]: Time started
- 2026-02-11 00:57:52 [Create mappers]: Time taken is 2.55ms (0.002s)
- 2026-02-11 00:57:52 [Total preload]: Time started
- 2026-02-11 00:57:52 [Preload mappers]: Time started
- 2026-02-11 00:57:52 Objects loaded: 116
- 2026-02-11 00:57:52 [Object Decoder]: Total time is 31.54ms (0.031s)
- 2026-02-11 00:57:52 [I/O Bound]: Total time is 0.88ms (0.000s)
- 2026-02-11 00:57:52 [Preload mappers]: Time taken is 32.58ms (0.032s)
- 2026-02-11 00:57:52 [Hookup relationships]: Time started
- 2026-02-11 00:57:52 [Hookup relationships]: Time taken is 6.81ms (0.006s)
- 2026-02-11 00:57:52 [Sort relationships]: Time started
- 2026-02-11 00:57:52 [Sort relationships]: Time taken is 4.19ms (0.004s)
- 2026-02-11 00:57:52 [Finalize loading]: Time started
- 2026-02-11 00:57:52 [Uninitialize Sound System 0x000002e3c9e4e200]: Time started
  2026-02-11 00:41:21 FMOD Studio Version 2.03.12, 64-bit, Qt 6.5.3 under LGPL, Build #160365
  2026-02-11 00:41:21 Operating System: Windows 11 Version 22H2; x86_64
  2026-02-11 00:41:21 Client ID: {e84bf153-30cb-4892-80b4-a5e2b9e74e12}
- 2026-02-11 00:41:21 [Initialize Sound System 0x000001fe6824a6e0]: Time started
  2026-02-11 00:41:21 Loaded plugin library "AudioGaming AudioMotors" (type 2) from C:/Program Files/FMOD SoundSystem/FMOD Studio 2.03.12/Plugins/audiogaming_audiomotors.dll
  2026-02-11 00:41:21 AudioGaming AudioMotors #0: "Drive" (type 0)
  2026-02-11 00:41:21 AudioGaming AudioMotors #1: "RPM" (type 0)
  2026-02-11 00:41:21 AudioGaming AudioMotors #2: "Transpose" (type 0)
  2026-02-11 00:41:21 AudioGaming AudioMotors #3: "Randomize" (type 0)
  2026-02-11 00:41:21 AudioGaming AudioMotors #4: "Adapt" (type 0)
  2026-02-11 00:41:21 AudioGaming AudioMotors #5: "Volume" (type 0)
  2026-02-11 00:41:21 AudioGaming AudioMotors #6: "Format" (type 1)
  2026-02-11 00:41:21 AudioGaming AudioMotors #7: "Car Data" (type 3)
  2026-02-11 00:41:21 AudioGaming AudioMotors #8: "Range" (type 0)
  2026-02-11 00:41:21 AudioGaming AudioMotors #9: "Sync" (type 1)
  2026-02-11 00:41:21 AudioGaming AudioMotors #10: "Mode" (type 1)
  2026-02-11 00:41:21 Loaded plugin library "AudioGaming AudioRain" (type 2) from C:/Program Files/FMOD SoundSystem/FMOD Studio 2.03.12/Plugins/audiogaming_audiorain.dll
  2026-02-11 00:41:21 AudioGaming AudioRain #0: "GlobalGain" (type 0)
  2026-02-11 00:41:21 AudioGaming AudioRain #1: "GlobalStrength" (type 0)
  2026-02-11 00:41:21 AudioGaming AudioRain #2: "AutoToManual" (type 0)
  2026-02-11 00:41:21 AudioGaming AudioRain #3: "GlobalMax" (type 0)
  2026-02-11 00:41:21 AudioGaming AudioRain #4: "GlobalRate" (type 0)
  2026-02-11 00:41:21 AudioGaming AudioRain #5: "GlobalAttack" (type 0)
  2026-02-11 00:41:21 AudioGaming AudioRain #6: "GlobalMin" (type 0)
  2026-02-11 00:41:21 AudioGaming AudioRain #7: "RumbleLevel" (type 0)
  2026-02-11 00:41:21 AudioGaming AudioRain #8: "RumbleDensity" (type 0)
  2026-02-11 00:41:21 AudioGaming AudioRain #9: "RumbleNotchQ" (type 0)
  2026-02-11 00:41:21 AudioGaming AudioRain #10: "RumbleHiCut" (type 0)
  2026-02-11 00:41:21 AudioGaming AudioRain #11: "RumbleLoCut" (type 0)
  2026-02-11 00:41:21 AudioGaming AudioRain #12: "RumbleCoupl" (type 0)
  2026-02-11 00:41:21 AudioGaming AudioRain #13: "ShowerLevel" (type 0)
  2026-02-11 00:41:21 AudioGaming AudioRain #14: "ShowerColor" (type 0)
  2026-02-11 00:41:21 AudioGaming AudioRain #15: "ShowerLoCut" (type 0)
  2026-02-11 00:41:21 AudioGaming AudioRain #16: "ShowerHiCut" (type 0)
  2026-02-11 00:41:21 AudioGaming AudioRain #17: "Liquid1Level" (type 0)
  2026-02-11 00:41:21 AudioGaming AudioRain #18: "Liquid1Density" (type 0)
  2026-02-11 00:41:21 AudioGaming AudioRain #19: "Liquid1Color" (type 0)
  2026-02-11 00:41:21 AudioGaming AudioRain #20: "Liquid1Visc" (type 0)
  2026-02-11 00:41:21 AudioGaming AudioRain #21: "Liquid1Min" (type 0)
  2026-02-11 00:41:21 AudioGaming AudioRain #22: "Liquid1Max" (type 0)
  2026-02-11 00:41:21 AudioGaming AudioRain #23: "Liquid1LoCut" (type 0)
  2026-02-11 00:41:21 AudioGaming AudioRain #24: "Liquid1HiCut" (type 0)
  2026-02-11 00:41:21 AudioGaming AudioRain #25: "Liquid2Level" (type 0)
  2026-02-11 00:41:21 AudioGaming AudioRain #26: "Liquid2Density" (type 0)
  2026-02-11 00:41:21 AudioGaming AudioRain #27: "Liquid2Color" (type 0)
  2026-02-11 00:41:21 AudioGaming AudioRain #28: "Liquid2Visc" (type 0)
  2026-02-11 00:41:21 AudioGaming AudioRain #29: "Liquid2Min" (type 0)
  2026-02-11 00:41:21 AudioGaming AudioRain #30: "Liquid2Max" (type 0)
  2026-02-11 00:41:21 AudioGaming AudioRain #31: "Liquid2LoCut" (type 0)
  2026-02-11 00:41:21 AudioGaming AudioRain #32: "Liquid2HiCut" (type 0)
  2026-02-11 00:41:21 AudioGaming AudioRain #33: "LFE" (type 0)
  2026-02-11 00:41:21 AudioGaming AudioRain #34: "LFECut" (type 0)
  2026-02-11 00:41:21 AudioGaming AudioRain #35: "Format" (type 1)
  2026-02-11 00:41:21 Loaded plugin library "AudioGaming AudioWeather" (type 2) from C:/Program Files/FMOD SoundSystem/FMOD Studio 2.03.12/Plugins/audiogaming_audioweather.dll
  2026-02-11 00:41:21 AudioGaming AudioWeather #0: "Wind" (type 0)
  2026-02-11 00:41:21 AudioGaming AudioWeather #1: "Rain" (type 0)
  2026-02-11 00:41:21 AudioGaming AudioWeather #2: "Volume" (type 0)
  2026-02-11 00:41:21 AudioGaming AudioWeather #3: "Weather Type" (type 1)
  2026-02-11 00:41:21 AudioGaming AudioWeather #4: "Format" (type 1)
  2026-02-11 00:41:21 Loaded plugin library "AudioGaming AudioWind" (type 2) from C:/Program Files/FMOD SoundSystem/FMOD Studio 2.03.12/Plugins/audiogaming_audiowind.dll
  2026-02-11 00:41:21 AudioGaming AudioWind #0: "GlobalGain" (type 0)
  2026-02-11 00:41:21 AudioGaming AudioWind #1: "GlobalSpeed" (type 0)
  2026-02-11 00:41:21 AudioGaming AudioWind #2: "AutoToManual" (type 0)
  2026-02-11 00:41:21 AudioGaming AudioWind #3: "GlobalMax" (type 0)
  2026-02-11 00:41:21 AudioGaming AudioWind #4: "GlobalRate" (type 0)
  2026-02-11 00:41:21 AudioGaming AudioWind #5: "GlobalAttack" (type 0)
  2026-02-11 00:41:21 AudioGaming AudioWind #6: "GlobalMin" (type 0)
  2026-02-11 00:41:21 AudioGaming AudioWind #7: "BackflowLevel" (type 0)
  2026-02-11 00:41:21 AudioGaming AudioWind #8: "BackflowShape" (type 1)
  2026-02-11 00:41:21 AudioGaming AudioWind #9: "BackflowFilter" (type 1)
  2026-02-11 00:41:21 AudioGaming AudioWind #10: "BackflowFreq" (type 0)
  2026-02-11 00:41:21 AudioGaming AudioWind #11: "BackflowQ" (type 0)
  2026-02-11 00:41:21 AudioGaming AudioWind #12: "BackflowRate" (type 0)
  2026-02-11 00:41:21 AudioGaming AudioWind #13: "VariationRange" (type 0)
  2026-02-11 00:41:21 AudioGaming AudioWind #14: "BackflowLoCut" (type 0)
  2026-02-11 00:41:21 AudioGaming AudioWind #15: "BackflowHiCut" (type 0)
  2026-02-11 00:41:21 AudioGaming AudioWind #16: "BackflowCoupl" (type 0)
  2026-02-11 00:41:21 AudioGaming AudioWind #17: "WhistlingLevel" (type 0)
  2026-02-11 00:41:21 AudioGaming AudioWind #18: "WhistlingShape" (type 1)
  2026-02-11 00:41:21 AudioGaming AudioWind #19: "WhistlingQ" (type 0)
  2026-02-11 00:41:21 AudioGaming AudioWind #20: "WhistlingFloor" (type 0)
  2026-02-11 00:41:21 AudioGaming AudioWind #21: "WhistlingRate" (type 0)
  2026-02-11 00:41:21 AudioGaming AudioWind #22: "WhistlingFmin" (type 0)
  2026-02-11 00:41:21 AudioGaming AudioWind #23: "WhistlingFmax" (type 0)
  2026-02-11 00:41:21 AudioGaming AudioWind #24: "WhistlingPres" (type 0)
  2026-02-11 00:41:21 AudioGaming AudioWind #25: "WhistlingLoCut" (type 0)
  2026-02-11 00:41:21 AudioGaming AudioWind #26: "WhistlingHiCut" (type 0)
  2026-02-11 00:41:21 AudioGaming AudioWind #27: "WhistlingCoupl" (type 0)
  2026-02-11 00:41:21 AudioGaming AudioWind #28: "GustsLevel" (type 0)
  2026-02-11 00:41:21 AudioGaming AudioWind #29: "GustsShape" (type 1)
  2026-02-11 00:41:21 AudioGaming AudioWind #30: "GustsMax" (type 0)
  2026-02-11 00:41:21 AudioGaming AudioWind #31: "GustsRate" (type 0)
  2026-02-11 00:41:21 AudioGaming AudioWind #32: "GustsAttack" (type 0)
  2026-02-11 00:41:21 AudioGaming AudioWind #33: "GustsMin" (type 0)
  2026-02-11 00:41:21 AudioGaming AudioWind #34: "GustsLoCut" (type 0)
  2026-02-11 00:41:21 AudioGaming AudioWind #35: "GustsHiCut" (type 0)
  2026-02-11 00:41:21 AudioGaming AudioWind #36: "GustsCoupl" (type 0)
  2026-02-11 00:41:21 AudioGaming AudioWind #37: "SquallsLevel" (type 0)
  2026-02-11 00:41:21 AudioGaming AudioWind #38: "SquallsShape" (type 1)
  2026-02-11 00:41:21 AudioGaming AudioWind #39: "SquallsAmp" (type 0)
  2026-02-11 00:41:21 AudioGaming AudioWind #40: "SquallsRate" (type 0)
  2026-02-11 00:41:21 AudioGaming AudioWind #41: "SquallsFloor" (type 0)
  2026-02-11 00:41:21 AudioGaming AudioWind #42: "SquallsLoCut" (type 0)
  2026-02-11 00:41:21 AudioGaming AudioWind #43: "SquallsHiCut" (type 0)
  2026-02-11 00:41:21 AudioGaming AudioWind #44: "SquallsCoupl" (type 0)
  2026-02-11 00:41:21 AudioGaming AudioWind #45: "LFE" (type 0)
  2026-02-11 00:41:21 AudioGaming AudioWind #46: "LFECut" (type 0)
  2026-02-11 00:41:21 AudioGaming AudioWind #47: "Format" (type 1)
  2026-02-11 00:41:21 Loaded plugin library "FMOD Haptics" (type 2) from C:/Program Files/FMOD SoundSystem/FMOD Studio 2.03.12/Plugins/fmod_haptics.dll
  2026-02-11 00:41:21 FMOD Haptics #0: "Clip" (type 3)
  2026-02-11 00:41:21 FMOD Haptics #1: "Finite Length" (type 3)
  2026-02-11 00:41:21 FMOD Haptics #2: "Intensity Left" (type 0)
  2026-02-11 00:41:21 FMOD Haptics #3: "Intensity Right" (type 0)
  2026-02-11 00:41:21 Loaded plugin library "FMOD Controller Output" (type 0) from C:/Program Files/FMOD SoundSystem/FMOD Studio 2.03.12/Plugins/fmod_output_controller.dll
  2026-02-11 00:41:21 Loaded plugin library "Resonance Audio Listener" (type 2) from C:/Program Files/FMOD SoundSystem/FMOD Studio 2.03.12/Plugins/resonanceaudio.dll
  2026-02-11 00:41:21 Resonance Audio Listener #0: "Gain" (type 0)
  2026-02-11 00:41:21 Resonance Audio Listener #1: "Room Properties" (type 3)
  2026-02-11 00:41:21 Loaded plugin library "Resonance Audio Soundfield" (type 2) from C:/Program Files/FMOD SoundSystem/FMOD Studio 2.03.12/Plugins/resonanceaudio.dll
  2026-02-11 00:41:21 Resonance Audio Soundfield #0: "Gain" (type 0)
  2026-02-11 00:41:21 Resonance Audio Soundfield #1: "3D Attributes" (type 3)
  2026-02-11 00:41:21 Resonance Audio Soundfield #2: "Overall Gain" (type 3)
  2026-02-11 00:41:21 Loaded plugin library "Resonance Audio Source" (type 2) from C:/Program Files/FMOD SoundSystem/FMOD Studio 2.03.12/Plugins/resonanceaudio.dll
  2026-02-11 00:41:21 Resonance Audio Source #0: "Gain" (type 0)
  2026-02-11 00:41:21 Resonance Audio Source #1: "Spread" (type 0)
  2026-02-11 00:41:21 Resonance Audio Source #2: "Dist Rolloff" (type 1)
  2026-02-11 00:41:21 Resonance Audio Source #3: "Occlusion" (type 0)
  2026-02-11 00:41:21 Resonance Audio Source #4: "Directivity" (type 0)
  2026-02-11 00:41:21 Resonance Audio Source #5: "Dir Sharpness" (type 0)
  2026-02-11 00:41:21 Resonance Audio Source #6: "Attenuation Ran" (type 3)
  2026-02-11 00:41:21 Resonance Audio Source #7: "3D Attributes" (type 3)
  2026-02-11 00:41:21 Resonance Audio Source #8: "Bypass Room" (type 2)
  2026-02-11 00:41:21 Resonance Audio Source #9: "Near-Field FX" (type 2)
  2026-02-11 00:41:21 Resonance Audio Source #10: "Near-Field Gain" (type 0)
  2026-02-11 00:41:21 Resonance Audio Source #11: "Overall Gain" (type 3)
- 2026-02-11 00:41:21 [Initialize Sound System 0x000001fe6824a6e0]: Time taken is 27.94ms (0.027s)
- 2026-02-11 00:41:21 [Total Load]: Time started
- 2026-02-11 00:41:21 [Opening]: Time started
- 2026-02-11 00:41:21 [Create mappers]: Time started
- 2026-02-11 00:41:21 [Create mappers]: Time taken is 3.92ms (0.003s)
- 2026-02-11 00:41:21 [Total preload]: Time started
- 2026-02-11 00:41:21 [Preload mappers]: Time started
- 2026-02-11 00:41:21 Objects loaded: 116
- 2026-02-11 00:41:21 [Object Decoder]: Total time is 37.31ms (0.037s)
- 2026-02-11 00:41:21 [I/O Bound]: Total time is 1.39ms (0.001s)
- 2026-02-11 00:41:21 [Preload mappers]: Time taken is 38.89ms (0.038s)
- 2026-02-11 00:41:21 [Hookup relationships]: Time started
- 2026-02-11 00:41:21 [Hookup relationships]: Time taken is 8.13ms (0.008s)
- 2026-02-11 00:41:21 [Sort relationships]: Time started
- 2026-02-11 00:41:21 [Sort relationships]: Time taken is 7.41ms (0.007s)
- 2026-02-11 00:41:21 [Finalize loading]: Time started
- 2026-02-11 00:41:21 [Uninitialize Sound System 0x000001fe6824a6e0]: Time started
Thank you for the logs.
Would it be possible, rather than installing FMOD, extracting the fmodstudio20312win64-installer.exe and then running FMOD Studio.exe directly.
You could try deleting the Plugins folder in the extracted installer as well.
Your suggestions seem to have worked for the first few times I’ve tried. At least side-by-side, at the moment I’m not able to open the one I have properly installed in Program Files, and the extracted version works.
I have that version in my documents folder, so maybe it’s a permissions issue, somehow? But launching the Program Files version as administrator also fails, so I have no idea what the core problem is.
I will update if this fails to continue to work in the near future!
