FMod distance filter are missing from plugins folder problem from Assetto Corsa
Hello, I have a problem with the distance filter, it feels like I don’t have this plugin and I have no idea where it is, how I can download and install it.
Without this plugin, the file stops working properly and the sounds that were changed by this file disappear in the game.
As you can see in the screenshot, the program says that the plugin is missing or damaged. I tried to solve this problem, but, having not found a way out, I create my own theme.
The original project was taken from the Assetto Corsa game (it is in the game files, but is used for the reason that it has settings for the throttle and other parts of the car prescribed in advance) If you pay attention, the program suggests that I delete the parts associated with this plugin. I looked to see if I could turn on the distance filter at all. As you can see, he is not on the list. The plugin will not appear depending on whether I delete or leave the “broken” old plugin marked with a yellow dotted line.
Please help me with solving this problem. Maybe I can somehow install a plug-in with a range filter for FMod and I won’t have to remove the filter, but I’ll just be able to click on the “update” button on the filter with the yellow line, maybe after installing the plug-in this error will disappear in principle.
I will be extremely grateful for the answer.
The version I work on: FMOD 2.02.23
The version on which the template program was originally written by the game developer: FMod 1.08.12 (Yes, the gap between versions is huge)
Thank you in advance, Maxim!)
The FMOD Distance Filter plugin is an example in the FMOD Core API examples, which are included with the FMOD Engine installer. Try building the fmod_distance_filter example to a .dll and add it to your FMOD Studio installation’s “plugins” directory, and see whether that resolves the issue.
If that doesn’t work, unfortunately I can’t be of any further help, as assistance with modding falls outside of the scope of support - I would recommend getting in touch with the Assetto Corsa modding community for more help with this issue.
