I added this old plug-in, FMOD Distance filter, on my project, I tried it on several versions of fmod, verified the path, I still have this shown as massing.
This method works on my colleague’s computer, we can’t see any difference between our two projects, we sure are updated. Any idea ?
For plugins you need to ensure that the plugin dll and .js file (if needed) are in either the installation root folder’s “plugins” folder or the project root folder’s “plugins” folder.
Then you need to ensure that the project itself is pointing to the correct folder for plugins. Open Edit > Preferences and ensure the “Plug-ins folder” setting is pointing to the correct folder if it is different.
