FMod GetStats disabled on IPhone
In fmod.cs in the fmod studio unity plugin, there is the following code:
#if !UNITY_IPHONE || UNITY_EDITOR
    public class Memory
        public static RESULT GetStats(ref int currentalloced, ref int maxalloced)
            return FMOD_Memory_GetStats(ref currentalloced, ref maxalloced, 1);
        #region importfunctions
        [DllImport (VERSION.dll)]
        private static extern RESULT FMOD_Memory_GetStats(ref int currentalloced, ref int maxalloced, int blocking);
        #endregion
#endif
Why is the “#if !UNITY_IPHONE” there? The libfmodstudiounityplugin.a seems to have it:
0000c5e4 t _FMOD_Memory_GetStats
Is this merely an oversight, or is there a reason why this is disabled? If so, what is the correct way to determine the amount of memory being used by FMOD at any given point on an IOS device? We would like to gather this data for telemetry purposes.
Hi wgkx,
Low level API access (including Memory GetStats) is coming soon to the Unity integration for all platforms. The reason Memory GetStats was disabled (as well as the rest of the low level API) on iOS is because Unity uses FMOD Ex internally and on iOS Unity has static linking. This means if we PInvoke that symbol we end up calling the the internal version and returning the memory usage of the internal audio system, not the Studio integration. We have renamed all the symbols to prevent the name collision and allowing us to expose the low level API in the next version.
For future reference there is a Unity specific FMOD Forum over here: viewforum.php?f=30
