FMOD on iOS/Android: multichannel output to OS spatial audio + Dolby Atmos for mobile
I’m building Sorle, an adaptive soundscape engine on FMOD Studio 2.03, and I’m looking at running the FMOD runtime inside a mobile app on iOS and Android. Our events are authored with a 7.1.4 master bus, and nearly all listeners will be on headphones.
I’ve been through the iOS and Android platform pages in the 2.03 manual but couldn’t find answers to the following:
  1. iOS: system Spatial Audio
    Can FMOD’s iOS output hand a multichannel stream (7.1.4, or 7.1/5.1 if that’s the ceiling) to Apple’s system Spatial Audio renderer when the route is AirPods or other headphones, where the route reports 2 output channels? Does FMOD work with AVAudioSession.setSupportsMultichannelContent (iOS 15+)? If so, which speaker mode and channel layout should we use, and is a 7.1.4 mix folded down before it reaches the OS?
  2. Android: Spatializer (API 33+)
    Can FMOD’s AAudio output open a multichannel stream with a channel mask that qualifies for Android’s Spatializer (Spatializer.canBeSpatialized), so the OS renders it binaurally with head tracking? Which layouts are supported?
  3. Dolby Atmos for mobile
    Dolby’s FMOD page says Atmos on mobile is handled by a Dolby Atmos renderer plug-in in FMOD, but their mobile games download page only lists a Wwise plug-in. Is there a currently available Dolby Atmos renderer plug-in for FMOD on iOS and Android?
  4. Performance
    Do you have guidance on CPU and battery cost for a 7.1.4 mix with a modest number of simultaneous events on current mid-range phones, compared with a stereo or binaural-plug-in setup? The use case is continuous playback over many hours.
Josef Falkensköld
Sorle
