Hello!
I’m trying to create a small app for raspberry pi 2 and I’d like to add to use FMOD on it. I have read somewhere that this is already supported but i cannot make it work.
I’m trying to use the armhf library and it doesn’t complains when the app loads it but when i try to execute the app somewhere in the library i get a SIGSEV when I create the FMOD::System.
I suppose this is not usable, but here is the “dump” I can see on gdb.
Program terminated with signal SIGSEGV, Segmentation fault.
#0 0x76e88174 in ?? () from /usr/lib/libfmod.so.6
(gdb) bt
#1 0x76e81880 in ?? () from /usr/lib/libfmod.so.6
