I use ps4-sdk 4.5 version, ue4.16,FMOD version fmodstudio10906ue4.16ps4_sdk4.5.zip
Run on ps4 development kit, cause follow error:
73:34:23 File root is /app0/!
73:34:23 Loaded symbols from /app0/symbols/development-symbols.bin!
73:34:23 FIOS2: built with SDK version 0x04508121
73:34:23 [SceLncUtil] W:\Build\J01934656\vsh\common_lib\lnc_util\src\lnc_util_ipc_client.cpp(352) getDbgExecutablePath: LNC_ISOK::0x80aa0003
73:34:24 Project file not found: …/…/…/Pupil2/Pupil2.uprojectLogInit:Display: Project file not found: …/…/…/Pupil2/Pupil2.uproject
73:34:24 LogInit:Display: Attempting to find via project info helper.
73:34:24 LogUProjectInfo: Found projects:
73:34:24 LogPlatformFile: Not using cached read wrapper
73:34:24 LogInit:Display: RandInit(14221988) SRandInit(14221988).
73:34:24 LogTaskGraph: Started task graph with 5 named threads and 17 total threads with 3 sets of task threads.
73:34:24 LogStats: Stats thread started at 0.470018
73:34:24 LogModuleManager:Warning: ModuleManager: Module ‘OnlineSubsystemPS4’ not found - its StaticallyLinkedModuleInitializers function is null.
73:34:24 Unable to find an IP address. This probably indicates that only the DEV LAN is connected, not LAN or WiFi. Returning 0.0.0.0 as the local host address.
73:34:24 LogInit: Build: ++UE4+Release-4.16-CL-0
73:34:24 LogInit: Engine Version: 4.16.3-0+++UE4+Release-4.16
73:34:24 LogInit: Compatible Engine Version: 4.16.0-0+++UE4+Release-4.16
73:34:24 LogInit: Net CL: 0
73:34:24 LogDevObjectVersion: Number of dev versions registered: 16
73:34:24 LogDevObjectVersion: Dev-Blueprints (B0D832E4-1F89-4F0D-ACCF-7EB736FD4AA2): 9
73:34:24 LogDevObjectVersion: Dev-Build (E1C64328-A22C-4D53-A36C-8E866417BD8C): 0
73:34:24 LogDevObjectVersion: Dev-Core (375EC13C-06E4-48FB-B500-84F0262A717E): 2
73:34:24 LogDevObjectVersion: Dev-Editor (E4B068ED-F494-42E9-A231-DA0B2E46BB41): 17
73:34:24 LogDevObjectVersion: Dev-Framework (CFFC743F-43B0-4480-9391-14DF171D2073): 23
73:34:24 LogDevObjectVersion: Dev-Mobile (B02B49B5-BB20-44E9-A304-32B752E40360): 0
73:34:24 LogDevObjectVersion: Dev-Networking (A4E4105C-59A1-49B5-A7C5-40C4547EDFEE): 0
73:34:24 LogDevObjectVersion: Dev-Online (39C831C9-5AE6-47DC-9A44-9C173E1C8E7C): 0
73:34:24 LogDevObjectVersion: Dev-Physics (78F01B33-EBEA-4F98-B9B4-84EACCB95AA2): 0
73:34:24 LogDevObjectVersion: Dev-Platform (6631380F-2D4D-43E0-8009-CF276956A95A): 0
73:34:24 LogDevObjectVersion: Dev-Rendering (12F88B9F-8875-4AFC-A67C-D90C383ABD29): 15
73:34:24 LogDevObjectVersion: Dev-Sequencer (7B5AE74C-D270-4C10-A958-57980B212A5A): 4
73:34:24 LogDevObjectVersion: Dev-VR (D7296918-1DD6-4BDD-9DE2-64A83CC13884): 0
73:34:24 LogDevObjectVersion: Dev-LoadTimes (C2A15278-BFE7-4AFE-6C17-90FF531DF755): 1
73:34:24 LogDevObjectVersion: Private-Geometry (6EACA3D4-40EC-4CC1-B786-8BED09428FC5): 1
73:34:24 LogDevObjectVersion: Dev-AnimPhys (29E575DD-E0A3-4627-9D10-D276232CDCEA): 3
73:34:24 LogInit: Compiled (64-bit): Aug 17 2017 11:12:20
73:34:24 LogInit: Compiled with Clang: 3.9.1 (PS4 clang version 4.50.0.331 eed02958)
73:34:24 LogInit: Build Configuration: Development
73:34:24 LogInit: Branch Name: ++UE4+Release-4.16
73:34:24 LogInit: Command line: -pak
73:34:24 LogInit: Base directory:
73:34:24 LogInit: Installed Engine Build: 0
73:34:24 LogInit: Presizing for max 2097152 objects, including 0 objects not considered by GC, pre-allocating 0 bytes for permanent pool.
73:34:24 LogStreaming:Display: Async Loading initialized: Event Driven Loader: true, Async Loading Thread: false
73:34:24 LogInit: Object subsystem initialized
73:34:24 [2017.08.17-09.01.20:979][ 0]LogPS4: Selected Device Profile: [PS4]
73:34:24 [2017.08.17-09.01.20:979][ 0]LogInit: Applying CVar settings loaded from the selected device profile: [PS4]
73:34:24 [2017.08.17-09.01.20:997][ 0]LogInit:Warning: Creating unregistered Device Profile CVar: [[sg.ConsoleScalability:0]]
73:34:24 [2017.08.17-09.01.20:998][ 0]LogInit: Computer: PS4 Devkit
73:34:24 [2017.08.17-09.01.20:998][ 0]LogInit: User: User1
73:34:24 [2017.08.17-09.01.20:998][ 0]LogInit: High frequency timer resolution =1.556658 MHz
73:34:24 [2017.08.17-09.01.20:999][ 0]LogInit: Memory sizes: Heap - 1766.53MB : Onion - 200.00MB : Garlic - 2600.00MB, Flexible - 344.00MB, Physical=4.8GB (5GB approx)
73:34:24
73:34:24 [2017.08.17-09.01.21:067][ 0]LogInit: Using OS detected language (zh-Hans).
73:34:24 [2017.08.17-09.01.21:067][ 0]LogInit: Using OS detected locale (zh-Hans).
73:34:24 [2017.08.17-09.01.21:069][ 0]LogTextLocalizationManager: No localization for ‘zh-Hans’ exists, so ‘en’ will be used for the language.
73:34:24 [2017.08.17-09.01.21:071][ 0]LogTextLocalizationManager: No localization for ‘zh-Hans’ exists, so ‘en’ will be used for the locale.
73:34:24 [2017.08.17-09.01.21:431][ 0]LogMaterial: Verifying Global Shaders for SF_PS4
73:34:24 [2017.08.17-09.01.21:493][ 0]LogSlate: Using Freetype 2.4.12
73:34:24 [2017.08.17-09.01.21:530][ 0]LogSlate: SlateFontCache - WITH_FREETYPE: 1, WITH_HARFBUZZ: 1
73:34:25 [2017.08.17-09.01.21:931][ 0]LogAssetRegistry: FAssetRegistry took 0.1210 seconds to start up
73:34:25 [2017.08.17-09.01.22:295][ 0]LogCollisionProfile:Warning: Profile (Graber) - Custom Channel Name = ‘GameTraceChannel3’ hasn’t been found
73:34:25 [2017.08.17-09.01.22:296][ 0]LogCollisionProfile:Warning: Profile (Graber) - Custom Channel Name = ‘GameTraceChannel4’ hasn’t been found
73:34:25 [2017.08.17-09.01.22:296][ 0]LogCollisionProfile:Warning: Profile (Graber) - Custom Channel Name = ‘GameTraceChannel5’ hasn’t been found
73:34:25 [2017.08.17-09.01.22:296][ 0]LogCollisionProfile:Warning: Profile (Graber) - Custom Channel Name = ‘GameTraceChannel6’ hasn’t been found
73:34:25 [2017.08.17-09.01.22:311][ 0]LogPackageLocalizationCache: Processed 4 localized package path(s) for 1 prioritized culture(s) in 0.014280 seconds
73:34:25 [2017.08.17-09.01.22:312][ 0]LogPakFile: New pak file …/…/…/pupil2/content/paks/pupil2-ps4.pak added to pak precacher.
73:34:25 [2017.08.17-09.01.22:363][ 0]LogContentStreaming: Texture pool size is 1000.00 MB
73:34:25 [2017.08.17-09.01.22:631][ 0]LogTemp:Warning: Search DLLPath Error!
73:34:26 [2017.08.17-09.01.22:704][ 0]LogNetVersion: Pupil2 , NetCL: 0, EngineNetVer: 2, GameNetVer: 0 (Checksum: 2206340199)
73:34:26 [2017.08.17-09.01.22:967][ 0]LogMoviePlayer: FAVMoviePlayer ctor…
73:34:26 [2017.08.17-09.01.22:968][ 0]LogMoviePlayer: Initializing movie player
73:34:26 [2017.08.17-09.01.22:970][ 0]LogPS4: PS4 User Service Event: LogIn - UserIndex: 0, UserID: 515186140
73:34:26 [2017.08.17-09.01.22:973][ 0]LogFMODOculus: StartupModule
73:34:26 [2017.08.17-09.01.22:973][ 0]LogFMOD: FFMODStudioModule startup
73:34:26 [2017.08.17-09.01.22:973][ 0]LogFMOD: Lib path = ‘…/…/…/Pupil2/Plugins/FMODStudio/Binaries’
73:34:26 [2017.08.17-09.01.22:973][ 0]LogFMOD: FFMODStudioModule::LoadDll: Loading libfmodL.prx
73:34:26 [2017.08.17-09.01.23:103][ 0]LogFMOD: FFMODStudioModule::LoadDll: Loading libfmodstudioL.prx
73:34:26 [2017.08.17-09.01.23:273][ 0]LogFMOD: Loading strings bank: …/…/…/pupil2/Content/FMOD/PS4/Master Bank.strings.bank
73:34:26 [2017.08.17-09.01.23:275][ 0]LogFMOD:Error: c:\jk\workspace\Build_UE4_4.16_1.9_PS4\studio_api\src\fmod_bankmodel.cpp(346) - Failed to open file ‘…/…/…/pupil2/Content/FMOD/PS4/Master Bank.strings.bank’
73:34:26
73:34:26 [2017.08.17-09.01.23:275][ 0]LogFMOD:Warning: Failed to load strings bank: …/…/…/pupil2/Content/FMOD/PS4/Master Bank.strings.bank
73:34:26 [2017.08.17-09.01.23:280][ 0]LogFMOD: Creating runtime Studio System
73:34:26 [2017.08.17-09.01.23:281][ 0]LogFMOD: Default sample rate = 48000
73:34:26 [2017.08.17-09.01.23:281][ 0]LogFMOD: System sample rate = 48000
73:34:26 [2017.08.17-09.01.23:281][ 0]LogFMOD: Matching system sample rate 48000
73:34:26 [2017.08.17-09.01.23:286][ 0]LogFMOD: Loading plugin ‘OculusSpatializerFMOD’
73:34:26 [2017.08.17-09.01.23:286][ 0]LogFMOD: Trying to load plugin file at location: /app0/prx/OculusSpatializerFMOD.prx
73:34:26 [2017.08.17-09.01.23:286][ 0]LogFMOD:Error: c:\jk\workspace\Build_UE4_4.16_1.9_PS4\lowlevel_api\platforms\orbis\src\fmod_os_misc.cpp(810) - sceKernelLoadStartModule returned 80020002
73:34:26
73:34:26
73:34:26 [2017.08.17-09.01.23:286][ 0]LogFMOD: Trying to load plugin file at location: /app0/prx/OculusSpatializerFMOD64.prx
73:34:26
73:34:26
73:34:26 [2017.08.17-09.01.23:286][ 0]LogFMOD: Trying to load plugin file at location: /app0/prx/libOculusSpatializerFMOD.prx
73:34:26 [2017.08.17-09.01.23:287][ 0]LogFMOD:Error: c:\jk\workspace\Build_UE4_4.16_1.9_PS4\lowlevel_api\platforms\orbis\src\fmod_os_misc.cpp(810) - sceKernelLoadStartModule returned 80020002
73:34:26
73:34:26
73:34:26 [2017.08.17-09.01.23:287][ 0]LogFMOD: Trying to load plugin file at location: /app0/prx/libOculusSpatializerFMOD64.prx
73:34:26
73:34:26
73:34:26 [2017.08.17-09.01.23:287][ 0]LogFMOD:Error: Failed to load plugin ‘OculusSpatializerFMOD’, sounds may not play
73:34:26 [2017.08.17-09.01.23:287][ 0]LogFMOD: Triggering Initialized on other modules
73:34:26 [2017.08.17-09.01.23:287][ 0]LogFMODOculus: FMOD_OSP_SUPPORTED is not enabled
73:34:26 [2017.08.17-09.01.23:287][ 0]LogFMOD: Loading Banks
73:34:26 [2017.08.17-09.01.23:325][ 0]LogFMOD:Error: c:\jk\workspace\Build_UE4_4.16_1.9_PS4\studio_api\src\fmod_bankmodel.cpp(346) - Failed to open file ‘…/…/…/pupil2/Content/FMOD/PS4/Master Bank.bank’
73:34:26
73:34:26 [2017.08.17-09.01.23:325][ 0]LogFMOD:Error: c:\jk\workspace\Build_UE4_4.16_1.9_PS4\studio_api\src\fmod_bankmodel.cpp(346) - Failed to open file ‘…/…/…/pupil2/Content/FMOD/PS4/Master Bank.strings.bank’
73:34:26
73:34:26 [2017.08.17-09.01.23:325][ 0]LogFMOD:Warning: Failed to bank: …/…/…/pupil2/Content/FMOD/PS4/Master Bank.bank (File does not exist)
73:34:26 [2017.08.17-09.01.23:325][ 0]LogFMOD:Warning: Failed to bank: …/…/…/pupil2/Content/FMOD/PS4/Master Bank.strings.bank (File does not exist)
73:34:26 [2017.08.17-09.01.23:325][ 0]LogAndroidPermission: UAndroidPermissionCallbackProxy::GetInstance
73:34:26 [2017.08.17-09.01.23:347][ 0]LogUObjectArray: 29958 objects as part of root set at end of initial load.
73:34:26 [2017.08.17-09.01.23:347][ 0]LogUObjectAllocator: 5815056 out of 0 bytes used by permanent object pool.
73:34:26 [2017.08.17-09.01.23:347][ 0]LogUObjectArray: CloseDisregardForGC: 0/0 objects in disregard for GC pool
73:34:26 [2017.08.17-09.01.23:348][ 0]LogEngine: Initializing Engine…
73:34:26 [2017.08.17-09.01.23:374][ 0]LogSocialScreen: SocialScreenStartup() bEnableSocialScreenSeparateMode is false, so the social screen will be in MirrorMode.
73:34:26 [2017.08.17-09.01.23:374][ 0]LogStreaming:Error: Couldn’t find file for package /Script/Engine requested by async loading code. NameToLoad: /Script/Engine
73:34:27 [2017.08.17-09.01.23:930][ 0]LogStats: UGameplayTagsManager::ConstructGameplayTagTree: Construct from data asset - 0.000 s
73:34:27 [2017.08.17-09.01.23:930][ 0]LogStats: UGameplayTagsManager::ConstructGameplayTagTree: GameplayTagTreeChangedEvent.Broadcast - 0.000 s
73:34:27 [2017.08.17-09.01.23:951][ 0]LogInit: FAudioDevice initialized.
73:34:27 [2017.08.17-09.01.23:952][ 0]LogInit: Texture streaming: Enabled
73:34:27 [2017.08.17-09.01.23:952][ 0]LogModuleManager:Warning: ModuleManager: Module ‘OnlineSubsystemPS4’ not found - its StaticallyLinkedModuleInitializers function is null.
73:34:27 [2017.08.17-09.01.24:027][ 0]LogStreaming:Error: Couldn’t find file for package /Game/FMOD/Events/Ghost/sister/Disappear requested by async loading code. NameToLoad: /Game/FMOD/Events/Ghost/sister/Disappear
73:34:27 [2017.08.17-09.01.24:050][ 0]LogStreaming:Error: Couldn’t find file for package /Game/FMOD/Events/Ghost/sister/BellFootstep requested by async loading code. NameToLoad: /Game/FMOD/Events/Ghost/sister/BellFootstep
73:34:27 [2017.08.17-09.01.24:051][ 0]LogStreaming:Error: Couldn’t find file for package /Game/FMOD/Events/Special_FX/jump_scare02 requested by async loading code. NameToLoad: /Game/FMOD/Events/Special_FX/jump_scare02
73:34:27 [2017.08.17-09.01.24:074][ 0]LogStreaming:Error: Couldn’t find file for package /Game/FMOD/Events/Genera_1/vase_1 requested by async loading code. NameToLoad: /Game/FMOD/Events/Genera_1/vase_1
73:34:27 [2017.08.17-09.01.24:075][ 0]LogStreaming:Error: Couldn’t find file for package /Game/FMOD/Events/Genera_1/Pillow_down requested by async loading code. NameToLoad: /Game/FMOD/Events/Genera_1/Pillow_down
73:34:27 [2017.08.17-09.01.24:075][ 0]LogStreaming:Error: Couldn’t find file for package /Game/FMOD/Events/Genera_1/Pillow requested by async loading code. NameToLoad: /Game/FMOD/Events/Genera_1/Pillow
73:34:27 [2017.08.17-09.01.24:075][ 0]LogStreaming:Error: Couldn’t find file for package /Game/FMOD/Events/Genera_1/PickStamp requested by async loading code. NameToLoad: /Game/FMOD/Events/Genera_1/PickStamp
73:34:27 [2017.08.17-09.01.24:075][ 0]LogStreaming:Error: Couldn’t find file for package /Game/FMOD/Events/Genera_1/Paper_down requested by async loading code. NameToLoad: /Game/FMOD/Events/Genera_1/Paper_down
73:34:27 [2017.08.17-09.01.24:076][ 0]LogStreaming:Error: Couldn’t find file for package /Game/FMOD/Events/Genera_1/Paper requested by async loading code. NameToLoad: /Game/FMOD/Events/Genera_1/Paper
73:34:27 [2017.08.17-09.01.24:076][ 0]LogStreaming:Error: Couldn’t find file for package /Game/FMOD/Events/Genera_1/key requested by async loading code. NameToLoad: /Game/FMOD/Events/Genera_1/key
73:34:27 [2017.08.17-09.01.24:076][ 0]LogStreaming:Error: Couldn’t find file for package /Game/FMOD/Events/Genera_1/EyeBallPick requested by async loading code. NameToLoad: /Game/FMOD/Events/Genera_1/EyeBallPick
73:34:27 [2017.08.17-09.01.24:076][ 0]LogStreaming:Error: Couldn’t find file for package /Game/FMOD/Events/Genera_1/chair_down requested by async loading code. NameToLoad: /Game/FMOD/Events/Genera_1/chair_down
73:34:27 [2017.08.17-09.01.24:077][ 0]LogStreaming:Error: Couldn’t find file for package /Game/FMOD/Events/Genera_1/chair requested by async loading code. NameToLoad: /Game/FMOD/Events/Genera_1/chair
73:34:27 [2017.08.17-09.01.24:140][ 0]LogStreaming:Error: Couldn’t find file for package /Game/FMOD/Events/Genera_1/Surface requested by async loading code. NameToLoad: /Game/FMOD/Events/Genera_1/Surface
73:34:27 [2017.08.17-09.01.24:153][ 0]LogStreaming:Error: Couldn’t find file for package /Game/FMOD/Events/Door_wood/UnlockDoor requested by async loading code. NameToLoad: /Game/FMOD/Events/Door_wood/UnlockDoor
73:34:27 [2017.08.17-09.01.24:153][ 0]LogStreaming:Error: Couldn’t find file for package /Game/FMOD/Events/Door_wood/OpenDoor_wood requested by async loading code. NameToLoad: /Game/FMOD/Events/Door_wood/OpenDoor_wood
73:34:27 [2017.08.17-09.01.24:153][ 0]LogStreaming:Error: Couldn’t find file for package /Game/FMOD/Events/Door_wood/LockDoor requested by async loading code. NameToLoad: /Game/FMOD/Events/Door_wood/LockDoor
73:34:27 [2017.08.17-09.01.24:153][ 0]LogStreaming:Error: Couldn’t find file for package /Game/FMOD/Events/Door_wood/CloseDoor_wood requested by async loading code. NameToLoad: /Game/FMOD/Events/Door_wood/CloseDoor_wood
73:34:27 [2017.08.17-09.01.24:154][ 0]LogStreaming:Error: Couldn’t find file for package /Game/FMOD/Events/Genera_1/OpenDraw requested by async loading code. NameToLoad: /Game/FMOD/Events/Genera_1/OpenDraw
73:34:27 [2017.08.17-09.01.24:167][ 0]LogStreaming:Error: Couldn’t find file for package /Game/FMOD/Events/General/Footsteps_wood_stairs requested by async loading code. NameToLoad: /Game/FMOD/Events/General/Footsteps_wood_stairs
73:34:27 [2017.08.17-09.01.24:168][ 0]LogStreaming:Error: Couldn’t find file for package /Game/FMOD/Events/General/Footsteps_wood requested by async loading code. NameToLoad: /Game/FMOD/Events/General/Footsteps_wood
73:34:31 [2017.08.17-09.01.27:787][ 0]LogTemp:Warning: Search DLLPath Error!
73:34:32 [2017.08.17-09.01.28:889][ 0]LogInit:Display: Game Engine Initialized.
73:34:32 [2017.08.17-09.01.28:890][ 0]LogInit:Display: Starting Game.
73:34:32 [2017.08.17-09.01.28:890][ 0]LogNet: Browse: /Game/GameMap/aaaaaa?Name=Player
73:34:32 [2017.08.17-09.01.28:891][ 0]LogLoad: LoadMap: /Game/GameMap/aaaaaa?Name=Player
