FMOD + SteamAudio Phonon Crashing Unity
Unity Crashes every time I hit play if using steam audio source. So I thought the issue was a steamaudio unity issue
But in FMOD 2.0.08. On build, FMOD shows an error “No FMOD symbols found in dynamic library phonon.dll”, and “error loading file.”
I’m at my wits end :slight_smile: Does anyone know a solution, or maybe a direction I can take to try and troubleshoot this?
Thanks in advance.
I see. Thank you! Their documentation states 1.10 and up, but I guess not :confused:
But that’s okay, I will miss all of the new bells and whistles, but I can certainly use 1.10. The only other necessary thing I need is the transceiver and it seems that you guys added that with v1.8
Cheers!
Just tried it with Versions 1.10.01 and 1.10.20, getting the same error in both, however with version 1.10.01, I’m getting the same error with “ffmpegsumo.dll”
Errors
00:24:43 fmod_pluginfactory.cpp(583), PluginFactory::loadPlugin(): No FMOD symbols found in dynamic library ‘C:/Program Files/FMOD SoundSystem/FMOD Studio 1.10.01/Plugins/steam/phonon.dll’
00:24:43 Error loading plugin C:/Program Files/FMOD SoundSystem/FMOD Studio 1.10.01/Plugins/steam/phonon.dll: Error loading file.
00:24:43 fmod_pluginfactory.cpp(583), PluginFactory::loadPlugin(): No FMOD symbols found in dynamic library ‘C:/Program Files/FMOD SoundSystem/FMOD Studio 1.10.01/Plugins/qtwebengine/ffmpegsumo.dll’
00:24:43 Error loading plugin C:/Program Files/FMOD SoundSystem/FMOD Studio 1.10.01/Plugins/qtwebengine/ffmpegsumo.dll: Error loading file.
Just a quick update, it’s def something wrong with my machine. I had someone else on the team test it and it worked fine. Any pointers on tracking this down?
Thanks
In the FMOD Unity Settings have you just added “phonon_fmod” to the plugin list?
If you have added “phonon” you will get the error message you mentioned.
I’ve added “phonon_fmod” to the plugin list. I haven’t added any other plugin.
I’m not getting a crash anymore, but still seeing a
I’m not seeing that at all, are you able to share the entire console log file?
Sure thing. Thank you!
Verbose Logs
17:02:07 FMOD Studio Version 2.01.00, 64-bit, Build #108403
17:02:07 Operating System: Windows 10 (10.0); x86_64
17:02:07 Client ID: {a2260790-460f-4e68-8af5-42d0800e9867}
17:02:07 [Initialize Sound System 0x000001e8890b0d00]: Time started
17:02:07 [Initialize Sound System 0x000001e8890b0d00]: Time taken is 40.99ms
17:02:08 [Initialize Sound System 0x000001e891673530]: Time started
17:02:08 Loaded plugin library “AudioGaming AudioMotors” (type 2) from C:/Program Files/FMOD SoundSystem/FMOD Studio 2.01.00/Plugins/audiogaming_audiomotors.dll
17:02:08 AudioGaming AudioMotors #0: “Drive” (type 0)
17:02:08 AudioGaming AudioMotors #1: “RPM” (type 0)
17:02:08 AudioGaming AudioMotors #2: “Transpose” (type 0)
17:02:08 AudioGaming AudioMotors #3: “Randomize” (type 0)
17:02:08 AudioGaming AudioMotors #4: “Adapt” (type 0)
17:02:08 AudioGaming AudioMotors #5: “Volume” (type 0)
17:02:08 AudioGaming AudioMotors #6: “Format” (type 1)
17:02:08 AudioGaming AudioMotors #7: “Car Data” (type 3)
17:02:08 AudioGaming AudioMotors #8: “Range” (type 0)
17:02:08 AudioGaming AudioMotors #9: “Sync” (type 1)
17:02:08 AudioGaming AudioMotors #10: “Mode” (type 1)
17:02:08 Loaded plugin library “AudioGaming AudioRain” (type 2) from C:/Program Files/FMOD SoundSystem/FMOD Studio 2.01.00/Plugins/audiogaming_audiorain.dll
17:02:08 AudioGaming AudioRain #0: “GlobalGain” (type 0)
17:02:08 AudioGaming AudioRain #1: “GlobalStrength” (type 0)
17:02:08 AudioGaming AudioRain #2: “AutoToManual” (type 0)
17:02:08 AudioGaming AudioRain #3: “GlobalMax” (type 0)
17:02:08 AudioGaming AudioRain #4: “GlobalRate” (type 0)
17:02:08 AudioGaming AudioRain #5: “GlobalAttack” (type 0)
17:02:08 AudioGaming AudioRain #6: “GlobalMin” (type 0)
17:02:08 AudioGaming AudioRain #7: “RumbleLevel” (type 0)
17:02:08 AudioGaming AudioRain #8: “RumbleDensity” (type 0)
17:02:08 AudioGaming AudioRain #9: “RumbleNotchQ” (type 0)
17:02:08 AudioGaming AudioRain #10: “RumbleHiCut” (type 0)
17:02:08 AudioGaming AudioRain #11: “RumbleLoCut” (type 0)
17:02:08 AudioGaming AudioRain #12: “RumbleCoupl” (type 0)
17:02:08 AudioGaming AudioRain #13: “ShowerLevel” (type 0)
17:02:08 AudioGaming AudioRain #14: “ShowerColor” (type 0)
17:02:08 AudioGaming AudioRain #15: “ShowerLoCut” (type 0)
17:02:08 AudioGaming AudioRain #16: “ShowerHiCut” (type 0)
17:02:08 AudioGaming AudioRain #17: “Liquid1Level” (type 0)
17:02:08 AudioGaming AudioRain #18: “Liquid1Density” (type 0)
17:02:08 AudioGaming AudioRain #19: “Liquid1Color” (type 0)
17:02:08 AudioGaming AudioRain #20: “Liquid1Visc” (type 0)
17:02:08 AudioGaming AudioRain #21: “Liquid1Min” (type 0)
17:02:08 AudioGaming AudioRain #22: “Liquid1Max” (type 0)
17:02:08 AudioGaming AudioRain #23: “Liquid1LoCut” (type 0)
17:02:08 AudioGaming AudioRain #24: “Liquid1HiCut” (type 0)
17:02:08 AudioGaming AudioRain #25: “Liquid2Level” (type 0)
17:02:08 AudioGaming AudioRain #26: “Liquid2Density” (type 0)
17:02:08 AudioGaming AudioRain #27: “Liquid2Color” (type 0)
17:02:08 AudioGaming AudioRain #28: “Liquid2Visc” (type 0)
17:02:08 AudioGaming AudioRain #29: “Liquid2Min” (type 0)
17:02:08 AudioGaming AudioRain #30: “Liquid2Max” (type 0)
17:02:08 AudioGaming AudioRain #31: “Liquid2LoCut” (type 0)
17:02:08 AudioGaming AudioRain #32: “Liquid2HiCut” (type 0)
17:02:08 AudioGaming AudioRain #33: “LFE” (type 0)
17:02:08 AudioGaming AudioRain #34: “LFECut” (type 0)
17:02:08 AudioGaming AudioRain #35: “Format” (type 1)
17:02:08 Loaded plugin library “AudioGaming AudioWeather” (type 2) from C:/Program Files/FMOD SoundSystem/FMOD Studio 2.01.00/Plugins/audiogaming_audioweather.dll
17:02:08 AudioGaming AudioWeather #0: “Wind” (type 0)
17:02:08 AudioGaming AudioWeather #1: “Rain” (type 0)
17:02:08 AudioGaming AudioWeather #2: “Volume” (type 0)
17:02:08 AudioGaming AudioWeather #3: “Weather Type” (type 1)
17:02:08 AudioGaming AudioWeather #4: “Format” (type 1)
17:02:08 Loaded plugin library “AudioGaming AudioWind” (type 2) from C:/Program Files/FMOD SoundSystem/FMOD Studio 2.01.00/Plugins/audiogaming_audiowind.dll
17:02:08 AudioGaming AudioWind #0: “GlobalGain” (type 0)
17:02:08 AudioGaming AudioWind #1: “GlobalSpeed” (type 0)
17:02:08 AudioGaming AudioWind #2: “AutoToManual” (type 0)
17:02:08 AudioGaming AudioWind #3: “GlobalMax” (type 0)
17:02:08 AudioGaming AudioWind #4: “GlobalRate” (type 0)
17:02:08 AudioGaming AudioWind #5: “GlobalAttack” (type 0)
17:02:08 AudioGaming AudioWind #6: “GlobalMin” (type 0)
17:02:08 AudioGaming AudioWind #7: “BackflowLevel” (type 0)
17:02:08 AudioGaming AudioWind #8: “BackflowShape” (type 1)
17:02:08 AudioGaming AudioWind #9: “BackflowFilter” (type 1)
17:02:08 AudioGaming AudioWind #10: “BackflowFreq” (type 0)
17:02:08 AudioGaming AudioWind #11: “BackflowQ” (type 0)
17:02:08 AudioGaming AudioWind #12: “BackflowRate” (type 0)
17:02:08 AudioGaming AudioWind #13: “VariationRange” (type 0)
17:02:08 AudioGaming AudioWind #14: “BackflowLoCut” (type 0)
17:02:08 AudioGaming AudioWind #15: “BackflowHiCut” (type 0)
17:02:08 AudioGaming AudioWind #16: “BackflowCoupl” (type 0)
17:02:08 AudioGaming AudioWind #17: “WhistlingLevel” (type 0)
17:02:08 AudioGaming AudioWind #18: “WhistlingShape” (type 1)
17:02:08 AudioGaming AudioWind #19: “WhistlingQ” (type 0)
17:02:08 AudioGaming AudioWind #20: “WhistlingFloor” (type 0)
17:02:08 AudioGaming AudioWind #21: “WhistlingRate” (type 0)
17:02:08 AudioGaming AudioWind #22: “WhistlingFmin” (type 0)
17:02:08 AudioGaming AudioWind #23: “WhistlingFmax” (type 0)
17:02:08 AudioGaming AudioWind #24: “WhistlingPres” (type 0)
17:02:08 AudioGaming AudioWind #25: “WhistlingLoCut” (type 0)
17:02:08 AudioGaming AudioWind #26: “WhistlingHiCut” (type 0)
17:02:08 AudioGaming AudioWind #27: “WhistlingCoupl” (type 0)
17:02:08 AudioGaming AudioWind #28: “GustsLevel” (type 0)
17:02:08 AudioGaming AudioWind #29: “GustsShape” (type 1)
17:02:08 AudioGaming AudioWind #30: “GustsMax” (type 0)
17:02:08 AudioGaming AudioWind #31: “GustsRate” (type 0)
17:02:08 AudioGaming AudioWind #32: “GustsAttack” (type 0)
17:02:08 AudioGaming AudioWind #33: “GustsMin” (type 0)
17:02:08 AudioGaming AudioWind #34: “GustsLoCut” (type 0)
17:02:08 AudioGaming AudioWind #35: “GustsHiCut” (type 0)
17:02:08 AudioGaming AudioWind #36: “GustsCoupl” (type 0)
17:02:08 AudioGaming AudioWind #37: “SquallsLevel” (type 0)
17:02:08 AudioGaming AudioWind #38: “SquallsShape” (type 1)
17:02:08 AudioGaming AudioWind #39: “SquallsAmp” (type 0)
17:02:08 AudioGaming AudioWind #40: “SquallsRate” (type 0)
17:02:08 AudioGaming AudioWind #41: “SquallsFloor” (type 0)
17:02:08 AudioGaming AudioWind #42: “SquallsLoCut” (type 0)
17:02:08 AudioGaming AudioWind #43: “SquallsHiCut” (type 0)
17:02:08 AudioGaming AudioWind #44: “SquallsCoupl” (type 0)
17:02:08 AudioGaming AudioWind #45: “LFE” (type 0)
17:02:08 AudioGaming AudioWind #46: “LFECut” (type 0)
17:02:08 AudioGaming AudioWind #47: “Format” (type 1)
17:02:08 fmod_pluginfactory.cpp(582), PluginFactory::loadPlugin(): No FMOD symbols found in dynamic library ‘C:/Program Files/FMOD SoundSystem/FMOD Studio 2.01.00/Plugins/phonon.dll’
17:02:08 Error loading plugin C:/Program Files/FMOD SoundSystem/FMOD Studio 2.01.00/Plugins/phonon.dll: Error loading file.
17:02:08 Loaded plugin library “Steam Audio Spatializer” (type 2) from C:/Program Files/FMOD SoundSystem/FMOD Studio 2.01.00/Plugins/phonon_fmod.dll
17:02:08 Steam Audio Spatializer #0: “DirectBinaural” (type 2)
17:02:08 Steam Audio Spatializer #1: “Interpolation” (type 1)
17:02:08 Steam Audio Spatializer #2: “Distance” (type 2)
17:02:08 Steam Audio Spatializer #3: “AirAbsorption” (type 2)
17:02:08 Steam Audio Spatializer #4: “OcclusionMode” (type 1)
17:02:08 Steam Audio Spatializer #5: “OcclusionMethod” (type 1)
17:02:08 Steam Audio Spatializer #6: “SourceRadius” (type 0)
17:02:08 Steam Audio Spatializer #7: “DirectLevel” (type 0)
17:02:08 Steam Audio Spatializer #8: “Indirect” (type 2)
17:02:08 Steam Audio Spatializer #9: “IndirBinaural” (type 2)
17:02:08 Steam Audio Spatializer #10: “IndirLevel” (type 0)
17:02:08 Steam Audio Spatializer #11: “IndirType” (type 1)
17:02:08 Steam Audio Spatializer #12: “StaticListener” (type 2)
17:02:08 Steam Audio Spatializer #13: “Name” (type 3)
17:02:08 Steam Audio Spatializer #14: “SourcePos” (type 3)
17:02:08 Steam Audio Spatializer #15: “DipoleWeight” (type 0)
17:02:08 Steam Audio Spatializer #16: “DipolePower” (type 0)
17:02:08 Steam Audio Spatializer #17: “HRTFIndex” (type 1)
17:02:08 Steam Audio Spatializer #18: “OverrideHRTF” (type 2)
17:02:08 Steam Audio Spatializer #19: “DP_Distance” (type 0)
17:02:08 Steam Audio Spatializer #20: “DP_AirAbsLow” (type 0)
17:02:08 Steam Audio Spatializer #21: “DP_AirAbsMid” (type 0)
17:02:08 Steam Audio Spatializer #22: “DP_AirAbsHigh” (type 0)
17:02:08 Steam Audio Spatializer #23: “DP_Delay” (type 0)
17:02:08 Steam Audio Spatializer #24: “DP_Occlusion” (type 0)
17:02:08 Steam Audio Spatializer #25: “DP_TransLow” (type 0)
17:02:08 Steam Audio Spatializer #26: “DP_TransMid” (type 0)
17:02:08 Steam Audio Spatializer #27: “DP_TransHigh” (type 0)
17:02:08 Steam Audio Spatializer #28: “DP_Directivity” (type 0)
17:02:08 Steam Audio Spatializer #29: “OverallGain” (type 3)
17:02:08 Loaded plugin library “Steam Audio Mixer Return” (type 2) from C:/Program Files/FMOD SoundSystem/FMOD Studio 2.01.00/Plugins/phonon_fmod.dll
17:02:08 Steam Audio Mixer Return #0: “IndirBinaural” (type 2)
17:02:08 Loaded plugin library “Steam Audio Reverb” (type 2) from C:/Program Files/FMOD SoundSystem/FMOD Studio 2.01.00/Plugins/phonon_fmod.dll
17:02:08 Steam Audio Reverb #0: “IndirBinaural” (type 2)
17:02:08 Steam Audio Reverb #1: “IndirType” (type 1)
17:02:08 Loaded plugin library “Resonance Audio Listener” (type 2) from C:/Program Files/FMOD SoundSystem/FMOD Studio 2.01.00/Plugins/resonanceaudio.dll
17:02:08 Resonance Audio Listener #0: “Gain” (type 0)
17:02:08 Resonance Audio Listener #1: “Room Properties” (type 3)
17:02:08 Loaded plugin library “Resonance Audio Soundfield” (type 2) from C:/Program Files/FMOD SoundSystem/FMOD Studio 2.01.00/Plugins/resonanceaudio.dll
17:02:08 Resonance Audio Soundfield #0: “Gain” (type 0)
17:02:08 Resonance Audio Soundfield #1: “3D Attributes” (type 3)
17:02:08 Resonance Audio Soundfield #2: “Overall Gain” (type 3)
17:02:08 Loaded plugin library “Resonance Audio Source” (type 2) from C:/Program Files/FMOD SoundSystem/FMOD Studio 2.01.00/Plugins/resonanceaudio.dll
17:02:08 Resonance Audio Source #0: “Gain” (type 0)
17:02:08 Resonance Audio Source #1: “Spread” (type 0)
17:02:08 Resonance Audio Source #2: “Min Distance” (type 0)
17:02:08 Resonance Audio Source #3: “Max Distance” (type 0)
17:02:08 Resonance Audio Source #4: “Dist Rolloff” (type 1)
17:02:08 Resonance Audio Source #5: “Occlusion” (type 0)
17:02:08 Resonance Audio Source #6: “Directivity” (type 0)
17:02:08 Resonance Audio Source #7: “Dir Sharpness” (type 0)
17:02:08 Resonance Audio Source #8: “3D Attributes” (type 3)
17:02:08 Resonance Audio Source #9: “Bypass Room” (type 2)
17:02:08 Resonance Audio Source #10: “Near-Field FX” (type 2)
17:02:08 Resonance Audio Source #11: “Near-Field Gain” (type 0)
17:02:08 Resonance Audio Source #12: “Overall Gain” (type 3)
17:02:08 [Initialize Sound System 0x000001e891673530]: Time taken is 281.16ms
17:02:09 [Total Load D:/FMOD/Forest Floor 4/Forest Floor 4.fspro 0x000001e891673c10]: Time started
17:02:09 [Opening D:/FMOD/Forest Floor 4/Forest Floor 4.fspro 0x000001e891673c10]: Time started
17:02:09 [Create mappers]: Time started
17:02:09 [Create mappers]: Time taken is 120.06ms
17:02:09 [Total preload]: Time started
17:02:09 [Preload mappers]: Time started
17:02:10 Objects loaded: 201
17:02:10 [Object Decoder]: Total time is 183.16ms
17:02:10 [I/O Bound]: Total time is 1120.77ms
17:02:10 [Preload mappers]: Time taken is 1304.55ms
17:02:10 [Hookup relationships]: Time started
17:02:10 [Hookup relationships]: Time taken is 29.62ms
17:02:10 [Sort relationships]: Time started
17:02:10 [Sort relationships]: Time taken is 23.71ms
17:02:10 [Finalize loading]: Time started
17:02:12 [Uninitialize Sound System 0x000001e891673530]: Time started
17:02:12 “FMOD_ERROR (8): DSP is already in the mixer’s DSP network. It must be removed before being reinserted or released.”
17:02:12 “FMOD_ERROR f:\jk\workspace\build__2.1__studio_win\studio\src\model\plugininfo.cpp(124): soundSystem()->system()->unloadPlugin(mHandle)”
17:02:12 [Uninitialize Sound System 0x000001e891673530]: Time taken is 17.40ms
17:02:12 [Initialize Sound System 0x000001e891673530]: Time started
17:02:12 Loaded plugin library “AudioGaming AudioMotors” (type 2) from C:/Program Files/FMOD SoundSystem/FMOD Studio 2.01.00/Plugins/audiogaming_audiomotors.dll
17:02:12 AudioGaming AudioMotors #0: “Drive” (type 0)
17:02:12 AudioGaming AudioMotors #1: “RPM” (type 0)
17:02:12 AudioGaming AudioMotors #2: “Transpose” (type 0)
17:02:12 AudioGaming AudioMotors #3: “Randomize” (type 0)
17:02:12 AudioGaming AudioMotors #4: “Adapt” (type 0)
17:02:12 AudioGaming AudioMotors #5: “Volume” (type 0)
17:02:12 AudioGaming AudioMotors #6: “Format” (type 1)
17:02:12 AudioGaming AudioMotors #7: “Car Data” (type 3)
17:02:12 AudioGaming AudioMotors #8: “Range” (type 0)
17:02:12 AudioGaming AudioMotors #9: “Sync” (type 1)
17:02:12 AudioGaming AudioMotors #10: “Mode” (type 1)
17:02:12 Loaded plugin library “AudioGaming AudioRain” (type 2) from C:/Program Files/FMOD SoundSystem/FMOD Studio 2.01.00/Plugins/audiogaming_audiorain.dll
17:02:12 AudioGaming AudioRain #0: “GlobalGain” (type 0)
17:02:12 AudioGaming AudioRain #1: “GlobalStrength” (type 0)
17:02:12 AudioGaming AudioRain #2: “AutoToManual” (type 0)
17:02:12 AudioGaming AudioRain #3: “GlobalMax” (type 0)
17:02:12 AudioGaming AudioRain #4: “GlobalRate” (type 0)
17:02:12 AudioGaming AudioRain #5: “GlobalAttack” (type 0)
17:02:12 AudioGaming AudioRain #6: “GlobalMin” (type 0)
17:02:12 AudioGaming AudioRain #7: “RumbleLevel” (type 0)
17:02:12 AudioGaming AudioRain #8: “RumbleDensity” (type 0)
17:02:12 AudioGaming AudioRain #9: “RumbleNotchQ” (type 0)
17:02:12 AudioGaming AudioRain #10: “RumbleHiCut” (type 0)
17:02:12 AudioGaming AudioRain #11: “RumbleLoCut” (type 0)
17:02:12 AudioGaming AudioRain #12: “RumbleCoupl” (type 0)
17:02:12 AudioGaming AudioRain #13: “ShowerLevel” (type 0)
17:02:12 AudioGaming AudioRain #14: “ShowerColor” (type 0)
17:02:12 AudioGaming AudioRain #15: “ShowerLoCut” (type 0)
17:02:12 AudioGaming AudioRain #16: “ShowerHiCut” (type 0)
17:02:12 AudioGaming AudioRain #17: “Liquid1Level” (type 0)
17:02:12 AudioGaming AudioRain #18: “Liquid1Density” (type 0)
17:02:12 AudioGaming AudioRain #19: “Liquid1Color” (type 0)
17:02:12 AudioGaming AudioRain #20: “Liquid1Visc” (type 0)
17:02:12 AudioGaming AudioRain #21: “Liquid1Min” (type 0)
17:02:12 AudioGaming AudioRain #22: “Liquid1Max” (type 0)
17:02:12 AudioGaming AudioRain #23: “Liquid1LoCut” (type 0)
17:02:12 AudioGaming AudioRain #24: “Liquid1HiCut” (type 0)
17:02:12 AudioGaming AudioRain #25: “Liquid2Level” (type 0)
17:02:12 AudioGaming AudioRain #26: “Liquid2Density” (type 0)
17:02:12 AudioGaming AudioRain #27: “Liquid2Color” (type 0)
17:02:12 AudioGaming AudioRain #28: “Liquid2Visc” (type 0)
17:02:12 AudioGaming AudioRain #29: “Liquid2Min” (type 0)
17:02:12 AudioGaming AudioRain #30: “Liquid2Max” (type 0)
17:02:12 AudioGaming AudioRain #31: “Liquid2LoCut” (type 0)
17:02:12 AudioGaming AudioRain #32: “Liquid2HiCut” (type 0)
17:02:12 AudioGaming AudioRain #33: “LFE” (type 0)
17:02:12 AudioGaming AudioRain #34: “LFECut” (type 0)
17:02:12 AudioGaming AudioRain #35: “Format” (type 1)
17:02:12 Loaded plugin library “AudioGaming AudioWeather” (type 2) from C:/Program Files/FMOD SoundSystem/FMOD Studio 2.01.00/Plugins/audiogaming_audioweather.dll
17:02:12 AudioGaming AudioWeather #0: “Wind” (type 0)
17:02:12 AudioGaming AudioWeather #1: “Rain” (type 0)
17:02:12 AudioGaming AudioWeather #2: “Volume” (type 0)
17:02:12 AudioGaming AudioWeather #3: “Weather Type” (type 1)
17:02:12 AudioGaming AudioWeather #4: “Format” (type 1)
17:02:12 Loaded plugin library “AudioGaming AudioWind” (type 2) from C:/Program Files/FMOD SoundSystem/FMOD Studio 2.01.00/Plugins/audiogaming_audiowind.dll
17:02:12 AudioGaming AudioWind #0: “GlobalGain” (type 0)
17:02:12 AudioGaming AudioWind #1: “GlobalSpeed” (type 0)
17:02:12 AudioGaming AudioWind #2: “AutoToManual” (type 0)
17:02:12 AudioGaming AudioWind #3: “GlobalMax” (type 0)
17:02:12 AudioGaming AudioWind #4: “GlobalRate” (type 0)
17:02:12 AudioGaming AudioWind #5: “GlobalAttack” (type 0)
17:02:12 AudioGaming AudioWind #6: “GlobalMin” (type 0)
17:02:12 AudioGaming AudioWind #7: “BackflowLevel” (type 0)
17:02:12 AudioGaming AudioWind #8: “BackflowShape” (type 1)
17:02:12 AudioGaming AudioWind #9: “BackflowFilter” (type 1)
17:02:12 AudioGaming AudioWind #10: “BackflowFreq” (type 0)
17:02:12 AudioGaming AudioWind #11: “BackflowQ” (type 0)
17:02:12 AudioGaming AudioWind #12: “BackflowRate” (type 0)
17:02:12 AudioGaming AudioWind #13: “VariationRange” (type 0)
17:02:12 AudioGaming AudioWind #14: “BackflowLoCut” (type 0)
17:02:12 AudioGaming AudioWind #15: “BackflowHiCut” (type 0)
17:02:12 AudioGaming AudioWind #16: “BackflowCoupl” (type 0)
17:02:12 AudioGaming AudioWind #17: “WhistlingLevel” (type 0)
17:02:12 AudioGaming AudioWind #18: “WhistlingShape” (type 1)
17:02:12 AudioGaming AudioWind #19: “WhistlingQ” (type 0)
17:02:12 AudioGaming AudioWind #20: “WhistlingFloor” (type 0)
17:02:12 AudioGaming AudioWind #21: “WhistlingRate” (type 0)
17:02:12 AudioGaming AudioWind #22: “WhistlingFmin” (type 0)
17:02:12 AudioGaming AudioWind #23: “WhistlingFmax” (type 0)
17:02:12 AudioGaming AudioWind #24: “WhistlingPres” (type 0)
17:02:12 AudioGaming AudioWind #25: “WhistlingLoCut” (type 0)
17:02:12 AudioGaming AudioWind #26: “WhistlingHiCut” (type 0)
17:02:12 AudioGaming AudioWind #27: “WhistlingCoupl” (type 0)
17:02:12 AudioGaming AudioWind #28: “GustsLevel” (type 0)
17:02:12 AudioGaming AudioWind #29: “GustsShape” (type 1)
17:02:12 AudioGaming AudioWind #30: “GustsMax” (type 0)
17:02:12 AudioGaming AudioWind #31: “GustsRate” (type 0)
17:02:12 AudioGaming AudioWind #32: “GustsAttack” (type 0)
17:02:12 AudioGaming AudioWind #33: “GustsMin” (type 0)
17:02:12 AudioGaming AudioWind #34: “GustsLoCut” (type 0)
17:02:12 AudioGaming AudioWind #35: “GustsHiCut” (type 0)
17:02:12 AudioGaming AudioWind #36: “GustsCoupl” (type 0)
17:02:12 AudioGaming AudioWind #37: “SquallsLevel” (type 0)
17:02:12 AudioGaming AudioWind #38: “SquallsShape” (type 1)
17:02:12 AudioGaming AudioWind #39: “SquallsAmp” (type 0)
17:02:12 AudioGaming AudioWind #40: “SquallsRate” (type 0)
17:02:12 AudioGaming AudioWind #41: “SquallsFloor” (type 0)
17:02:12 AudioGaming AudioWind #42: “SquallsLoCut” (type 0)
17:02:12 AudioGaming AudioWind #43: “SquallsHiCut” (type 0)
17:02:12 AudioGaming AudioWind #44: “SquallsCoupl” (type 0)
17:02:12 AudioGaming AudioWind #45: “LFE” (type 0)
17:02:12 AudioGaming AudioWind #46: “LFECut” (type 0)
17:02:12 AudioGaming AudioWind #47: “Format” (type 1)
17:02:12 fmod_pluginfactory.cpp(582), PluginFactory::loadPlugin(): No FMOD symbols found in dynamic library ‘C:/Program Files/FMOD SoundSystem/FMOD Studio 2.01.00/Plugins/phonon.dll’
17:02:12 Error loading plugin C:/Program Files/FMOD SoundSystem/FMOD Studio 2.01.00/Plugins/phonon.dll: Error loading file.
17:02:12 Loaded plugin library “Steam Audio Spatializer” (type 2) from C:/Program Files/FMOD SoundSystem/FMOD Studio 2.01.00/Plugins/phonon_fmod.dll
17:02:12 Steam Audio Spatializer #0: “DirectBinaural” (type 2)
17:02:12 Steam Audio Spatializer #1: “Interpolation” (type 1)
17:02:12 Steam Audio Spatializer #2: “Distance” (type 2)
17:02:12 Steam Audio Spatializer #3: “AirAbsorption” (type 2)
17:02:12 Steam Audio Spatializer #4: “OcclusionMode” (type 1)
17:02:12 Steam Audio Spatializer #5: “OcclusionMethod” (type 1)
17:02:12 Steam Audio Spatializer #6: “SourceRadius” (type 0)
17:02:12 Steam Audio Spatializer #7: “DirectLevel” (type 0)
17:02:12 Steam Audio Spatializer #8: “Indirect” (type 2)
17:02:12 Steam Audio Spatializer #9: “IndirBinaural” (type 2)
17:02:12 Steam Audio Spatializer #10: “IndirLevel” (type 0)
17:02:12 Steam Audio Spatializer #11: “IndirType” (type 1)
17:02:12 Steam Audio Spatializer #12: “StaticListener” (type 2)
17:02:12 Steam Audio Spatializer #13: “Name” (type 3)
17:02:12 Steam Audio Spatializer #14: “SourcePos” (type 3)
17:02:12 Steam Audio Spatializer #15: “DipoleWeight” (type 0)
17:02:12 Steam Audio Spatializer #16: “DipolePower” (type 0)
17:02:12 Steam Audio Spatializer #17: “HRTFIndex” (type 1)
17:02:12 Steam Audio Spatializer #18: “OverrideHRTF” (type 2)
17:02:12 Steam Audio Spatializer #19: “DP_Distance” (type 0)
17:02:12 Steam Audio Spatializer #20: “DP_AirAbsLow” (type 0)
17:02:12 Steam Audio Spatializer #21: “DP_AirAbsMid” (type 0)
17:02:12 Steam Audio Spatializer #22: “DP_AirAbsHigh” (type 0)
17:02:12 Steam Audio Spatializer #23: “DP_Delay” (type 0)
17:02:12 Steam Audio Spatializer #24: “DP_Occlusion” (type 0)
17:02:12 Steam Audio Spatializer #25: “DP_TransLow” (type 0)
17:02:12 Steam Audio Spatializer #26: “DP_TransMid” (type 0)
17:02:12 Steam Audio Spatializer #27: “DP_TransHigh” (type 0)
17:02:12 Steam Audio Spatializer #28: “DP_Directivity” (type 0)
17:02:12 Steam Audio Spatializer #29: “OverallGain” (type 3)
17:02:12 Loaded plugin library “Steam Audio Mixer Return” (type 2) from C:/Program Files/FMOD SoundSystem/FMOD Studio 2.01.00/Plugins/phonon_fmod.dll
17:02:12 Steam Audio Mixer Return #0: “IndirBinaural” (type 2)
17:02:12 Loaded plugin library “Steam Audio Reverb” (type 2) from C:/Program Files/FMOD SoundSystem/FMOD Studio 2.01.00/Plugins/phonon_fmod.dll
17:02:12 Steam Audio Reverb #0: “IndirBinaural” (type 2)
17:02:12 Steam Audio Reverb #1: “IndirType” (type 1)
17:02:12 Loaded plugin library “Resonance Audio Listener” (type 2) from C:/Program Files/FMOD SoundSystem/FMOD Studio 2.01.00/Plugins/resonanceaudio.dll
17:02:12 Resonance Audio Listener #0: “Gain” (type 0)
17:02:12 Resonance Audio Listener #1: “Room Properties” (type 3)
17:02:12 Loaded plugin library “Resonance Audio Soundfield” (type 2) from C:/Program Files/FMOD SoundSystem/FMOD Studio 2.01.00/Plugins/resonanceaudio.dll
17:02:12 Resonance Audio Soundfield #0: “Gain” (type 0)
17:02:12 Resonance Audio Soundfield #1: “3D Attributes” (type 3)
17:02:12 Resonance Audio Soundfield #2: “Overall Gain” (type 3)
17:02:12 Loaded plugin library “Resonance Audio Source” (type 2) from C:/Program Files/FMOD SoundSystem/FMOD Studio 2.01.00/Plugins/resonanceaudio.dll
17:02:12 Resonance Audio Source #0: “Gain” (type 0)
17:02:12 Resonance Audio Source #1: “Spread” (type 0)
17:02:12 Resonance Audio Source #2: “Min Distance” (type 0)
17:02:12 Resonance Audio Source #3: “Max Distance” (type 0)
17:02:12 Resonance Audio Source #4: “Dist Rolloff” (type 1)
17:02:12 Resonance Audio Source #5: “Occlusion” (type 0)
17:02:12 Resonance Audio Source #6: “Directivity” (type 0)
17:02:12 Resonance Audio Source #7: “Dir Sharpness” (type 0)
17:02:12 Resonance Audio Source #8: “3D Attributes” (type 3)
17:02:12 Resonance Audio Source #9: “Bypass Room” (type 2)
17:02:12 Resonance Audio Source #10: “Near-Field FX” (type 2)
17:02:12 Resonance Audio Source #11: “Near-Field Gain” (type 0)
17:02:12 Resonance Audio Source #12: “Overall Gain” (type 3)
17:02:12 [Initialize Sound System 0x000001e891673530]: Time taken is 679.04ms
17:02:31 [Finalize loading]: Time taken is 20297.38ms
17:02:31 [Total preload]: Time taken is 21656.08ms
17:02:31 Macro: Project recovery
17:02:31 [Resync auditioning D:/FMOD/Forest Floor 4/Forest Floor 4.fspro 0x000001e891673c10]: Time started
17:02:31 [Resync Auditioning Queue 0x000001e891673530]: Time started
17:02:31 Resyncing (build: 68, delete: 0, mute: 0)
17:02:31 fmod_objectlookup.h(122), ObjectLookup::get(): Lookup failed for ParameterLayoutModel: {fd43d611-3f05-0b51-070a-8ebd288c9853}
17:02:31 fmod_objectlookup.h(122), ObjectLookup::get(): Lookup failed for ParameterLayoutModel: {c96b30a1-d5ac-04bc-3cbb-1202de5c7ad8}
17:02:31 fmod_objectlookup.h(122), ObjectLookup::get(): Lookup failed for ParameterLayoutModel: {699314b0-d8d4-0489-39b8-2dd01b2dffca}
17:02:31 fmod_objectlookup.h(122), ObjectLookup::get(): Lookup failed for ParameterLayoutModel: {9c406983-802d-041e-349d-136f0026f960}
17:02:31 fmod_objectlookup.h(122), ObjectLookup::get(): Lookup failed for ParameterLayoutModel: {4202cd5f-a8b5-0ad8-0a88-b85762303ff7}
17:02:31 fmod_objectlookup.h(122), ObjectLookup::get(): Lookup failed for ParameterLayoutModel: {6bf47f53-abad-0f50-2567-21089758718a}
17:02:31 fmod_objectlookup.h(122), ObjectLookup::get(): Lookup failed for ParameterLayoutModel: {2ec56f25-e9c8-0191-066a-e82471e23180}
17:02:31 [Resync Auditioning Queue 0x000001e891673530]: Time taken is 9.35ms
17:02:31 [Resync auditioning D:/FMOD/Forest Floor 4/Forest Floor 4.fspro 0x000001e891673c10]: Time taken is 9.42ms
17:02:31 [Opening D:/FMOD/Forest Floor 4/Forest Floor 4.fspro 0x000001e891673c10]: Time taken is 21997.51ms
17:02:31 [Total Load D:/FMOD/Forest Floor 4/Forest Floor 4.fspro 0x000001e891673c10]: Time taken is 22136.49ms
17:02:31 ScriptServer started on 0.0.0.0 (3663)
17:02:32 Event activated: [None] [#2 times]
17:02:32 Activated ‘Forest Floor 4.fspro[*] - Event Editor’ for ‘D:/FMOD/Forest Floor 4/Forest Floor 4.fspro’
17:02:37 Activated ‘Forest Floor 4.fspro[*] - Console’ for ‘D:/FMOD/Forest Floor 4/Forest Floor 4.fspro’
Oh in Studio I am getting that, I thought you were talking about Unity sorry.
You should be able to ignore that and still have it work.
