Fmod Studio API - How to play in a specific soundcard
I’m very familiar with the fmodex and know how the setdriver works.
I’ve started a new project using the studio api, and I can’t get the api to play sounds in a soundcard that is not the default.
Using ObjectPan.cpp
FMOD::Studio::System *system = NULL;
ERRCHECK( FMOD::Studio::System::create(&system) );
FMOD::System* lowLevelSystem = NULL;
ERRCHECK( lowLevelSystem->setDriver(1) );
The line above looks like it’s ignored and the sound is always playing in the default soundcard.
I’m using the latest version of studio dll.
I did some more research, and it seems related to the sound_output
If I comment:
FMOD_RESULT result = lowLevelSystem->setOutput(FMOD_OUTPUTTYPE_AUDIO3D);
It plays fine in the driver 1,
but if the output it’s AUDIO3D, does not matter what I do, it will play in the default soundcard driver = 0
What you will want to do is use System::getNumDrivers and iterate over the drivers, using System::getDriverInfo to determine the driver you are looking for. Then use setDriver with the index of the driver you want to use.
https://fmod.com/resources/documentation-api?page=content/generated/FMOD_System_GetDriverInfo.html
Yes, I know, I’m just hard coding 1
to see if works.
