Paste ofCode Here is my player movement script
Paste ofCode Finally my audio manager
I am trying to get footstep sounds to play, and i put debug.logs to check and it all seems fine, but the audio just isn’t playing
It appears your code links have expired - if you’re still running into the issue, could I get you to post them again? Additionally, can I would recommend doing a few other things:
Debug.Log(), as they return FMOD_RESULT which will provide you with more information.
